playback command
Hi all,
I have been going nuts trying to remember the syntax for this and I am hoping someone here can put me straight!
96=playback 2514 ,hello-world
in my rpt.conf file in the functions stanza. 2514 is the node number and hello-world is just an example sound file from the atserisk/sounds directory.
I had this working once upon a time but now I just cant seem to get the syntax right to get it to work.
All I want to do is to call a voice ID file from the scheduler by calling a macro, so I need to define a dtmf code to it so the macro can run the fiunction.
Matt
G4RKY
Matt Beasant wrote:
Hi all,
<-- Hi Matt; try this...
96=playback 2514,rpt/hello-world
Note that 'playback' will play the file globally, so all nodes connected to 2514 will hear the announcement (use with caution!).
In the above example, the 'hello-world' file is located in the following dir:
/var/lib/asterisk/sounds/rpt
HTH - and I look forward to the news about the 220 gear!
Ramesh.
Ramesh Dhami (VA3UV) wrote:
Matt Beasant wrote:
Hi all,
dir:
Ramesh.
[email protected]
This is how it's used:
; Playback messages
931000=playback,rpt/sitenorm ; site normal message
931001=playback,rpt/alllinksdisconnected; all links disconnected
931002=playback,rpt/alllinksrestored ; all links restored
Please not that playback is semi-broken in that it only plays back locally.
This is logged in mantis.
Steve
WA6ZFT
Ah, thank you both for the replies.
I have this working now Stephen, thanks for that.
Now I have another related ( loosely ) question.
I wanted to use this function to play a voice ID at the top of the hour on a repeater.
I have just ( yesterday ) added an additonal node to my system at Dundry and now have two nodes running on 1 machine.
The instructions to achieve this were great and its easy to do, but there was one part I wasnt 100% sure about.
In RPT.CONF, where do I put my configuration for the second node?
Do I put it right at the very end of the existing config, after the scheduler section or do I put it after the node definition, after the statpost commands?
I’ll give it a try at the very end and see what happens…
Matt
2009/11/23 Stephen Rodgers [email protected]
Matt Beasant wrote:
Hi all,
← Hi Matt; try this…
Note that ‘playback’ will play the file globally, so all nodes connected
In the above example, the ‘hello-world’ file is located in the following
dir:
Ramesh.
[email protected]
This is how it’s used:
; Playback messages
Steve
WA6ZFT
[email protected]
Yep got this all working as intended now.
Thanks guys for all your help.
Kind regards
Matt
Sent from my BlackBerry® wireless device
Date: Mon, 23 Nov 2009 18:38:00 +0000
To: [email protected]
Cc: [email protected]; app_rpt[email protected]
Subject: Re: [App_rpt-users] playback command
Matt
Matt Beasant wrote:
Hi all,
dir:
Ramesh.
[email protected]
; Playback messages
Steve
WA6ZFT
[email protected]
Kind regards
Matt
Sent from my BlackBerry� wireless device
*Date: *Mon, 23 Nov 2009 18:38:00 +0000
*To: *<[email protected]>
*Cc: *<[email protected]>; app_rpt<[email protected]>
*Subject: *Re: [App_rpt-users] playback command
I'll give it a try at the very end and see what happens....
Matt
2009/11/23 Stephen Rodgers <[email protected] <mailto:[email protected]>>
    > Matt Beasant wrote:
    >> Hi all,
    >> I have been going nuts trying to remember the syntax for this
    and I am
    >> hoping someone here can put me straight!
    >> 96=playback 2514 ,hello-world
    > <-- Hi Matt; try this...
    > 96=playback 2514,rpt/hello-world
    > Note that 'playback' will play the file globally, so all nodes
    connected
    > to 2514 will hear the announcement (use with caution!).
    > In the above example, the 'hello-world' file is located in the
    following
    > dir:
    > /var/lib/asterisk/sounds/rpt
    > HTH - and I look forward to the news about the 220 gear!
    > Ramesh.
    >_______________________________________________
    > App_rpt-users mailing list
    > [email protected] <mailto:[email protected]>
    > http://qrvc.com/mailman/listinfo/app_rpt-users
    ; Playback messages
    locally.
    Steve
    WA6ZFT
This message has been scanned for viruses and
dangerous content by *MailScanner* <http://www.mailscanner.info/&gt;, and is
believed to be clean.
[email protected]
If you've not done this already be sure to try:
rpt playback <node#> tt-weasels
Trust me.. it's worthwhile.
If that's not your fancy there's always tt-monkeys
:slight_smile:
Steve
dangerous content by MailScanner, and is
If you’ve not done this already be sure to try:
Trust me… it’s worthwhile.
If that’s not your fancy there’s always tt-monkeys
:slight_smile:
Steve
heh heh nice one Steve, yes all sorts of fun can be had now!
Just to tie the ribbons on my related question, I now have my 2 nodes working great using two separate stanzas in rpt.conf.
I wasnt sure of this would work but its working out well - I have two complete sets of node configs, I left the original one as it was and pasted a whole new one underneath it and renamed all the stanzas with a suffix of the repeater’s callsign so I know what I am doing when I edit it.
The more I find out about app_rpt the more**I love it!
Matt
