Play two audio files back to back
I am currently writing scripts for my remote base, and am working on the channel switch acknowledgment.
Here is what I am currently doing:
asterisk -rx “rpt playback $node channel”
asterisk -rx “rpt playback $node digits/$chan”
This works well for my 16 channel radio, but I am annoyed by the amount of space between the audio files.
I tried stuff like
asterisk -rx “rpt playback $node channel & digits/$chan”
but I just get a syntax error.
Does anybody know the solution to get the audio files to play back to back like they do when AllStar announces node connections etc?
Skyler KDØWHB\
Leading and trailing spaces with the & are not tolerated.
e.g filename&filename2 OK
filename & filename2 Not OK
Bob
kk6ecm
Sent from iPad
asterisk -rx "rpt playback $node channel"
asterisk -rx "rpt playback $node digits/$chan"
I tried stuff like
asterisk -rx "rpt playback $node channel & digits/$chan"
Skyler KDØWHB\
Small Problem:
rpt playback 42622 channel&channel
ast_streamfile: Unable to open channel&channel
Skyler
Bob
kk6ecm
Sent from iPad
I tried stuff like
Skyler KDØWHB\
Skyler Fennell
amsatnet.info
KDØWHB
Hmmm … appears to be a mix of two syntaxes, and you may not achieve your goal…
Xxxxxxx*CLI> help rpt playback
Usage: rpt playback <sound_file_base_name>
Send an Audio File to a node, send to all other connected nodes (global)
(seems there used to be a as a third variable)
and
playback, file&file1 on the current node, where the concatenated files are joined with the &, no spaces.
I’m wondering… set delay to 0… not sure if there is a default, or even if it is still a feature.
e.g.
Bob
kk6ecm
asterisk -rx “rpt playback $node channel 0”
asterisk -rx “rpt playback $node digits/$chan 0”
Bob
kk6ecm
Sent from iPad
I tried stuff like
Skyler KDØWHB\
Skyler Fennell
amsatnet.info
KDØWHB
That apparently isn’t a feature anymore
root@pistar:~# asterisk -rx “rpt playback $node channel 0”
and
e.g.
Bob
kk6ecm
Sent from iPad
On Apr 25, 2016, at 9:26 PM, Skyler F electricity440@gmail.com wrote:
Small Problem:
Skyler
Bob
kk6ecm
Sent from iPad
I tried stuff like
Skyler KDØWHB\
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
I think the playback command only takes a single audio filename.
Try this approach:
cat /var/lib/asterisk/sounds/tide.gsm > /tmp/temp.gsm
cat /var/lib/asterisk/sounds/times.gsm >> /tmp/temp.gsm
cat /var/lib/asterisk/sounds/will-expire.gsm >> /tmp/temp.gsm
cat /var/lib/asterisk/sounds/at-any-time.gsm >> /tmp/temp.gsm
asterisk -rx "rpt playback $node /tmp/temp"
rm -f /tmp/temp.gsm
Note that once these audio segments are cat'ed together, a final call to
sox can be used to change levels, formats, etc., if needed.
73, David KB4FXC
On Tue, 26 Apr 2016, kk6ecm wrote:
Hmmm ... appears to be a mix of two syntaxes, and you may not achieve your goal...
Usage: rpt playback <nodename> <sound_file_base_name>
            (seems there used to be a <delay> as a third variable)
and
I'm wondering... set delay to 0... not sure if there is a default, or even if it is still a feature.
e.g.
>> asterisk -rx "rpt playback $node channel 0"
>> > asterisk -rx "rpt playback $node digits/$chan 0"
Bob
kk6ecm
Sent from iPad
> On Apr 25, 2016, at 9:26 PM, Skyler F <electricity440@gmail.com> wrote:
> Small Problem:
> 73
> Skyler
>> Thanks,
>> Bob
>> kk6ecm
>> 73
>> Sent from iPad
>> > I tried stuff like
>> > 73
>> > Skyler KDØWHB\
>> > _______________________________________________
>> > App_rpt-users mailing list
>> > You do not need a password to unsubscribe, you can do it via email confirmation. If you have trouble unsubscribing, please send a message to the list detailing the problem.
> Skyler Fennell
> amsatnet.info
> KDØWHB
Or, if you are using WAV files ... catwav them (which uses sox) and play the result ...
/bin/rm -f $WXT/$TEMPMSG #Make filename available for output
/usr/local/bin/catwav $WXT/$TAILMSG $WXA/${P1}${P2}${P3} $WXT/$TEMPMSG
/bin/rm -f $WXT/$TAILMSG #Make filename available for output
/usr/local/bin/catwav $WXT/$TEMPMSG $WXA/spc.wav $WXT/$TAILMSG
You would do the asterisk -rx " rpt localplay NODE cattedfile" here (I use it to build tailmessages with multiple announcements).
...STeve - KF5VH
Try this approach:
rm -f /tmp/temp.gsm
73, David KB4FXC
and
e.g.
Bob
kk6ecm
Sent from iPad
Small Problem:
Skyler
Bob
kk6ecm
Sent from iPad
I tried stuff like
Skyler KDØWHB\
Skyler Fennell
amsatnet.info
KDØWHB
Thanks David and Steve.
The cat method works perfect other then a tiny detail:
rm -f /tmp/temp.gsm deletes the file before it is finished playing so you don’t hear the audio. Removing the line actually didn’t cause issues, but I added a sleep and then delete the file just in case.
The method isn’t as elegant, but gets the job done and I don’t hear the spaces anymore!
Skyler
On Tue, Apr 26, 2016 at 6:08 AM, Steve Mahler kizzy@lusfiber.net wrote:
Or, if you are using WAV files … catwav them (which uses sox) and play the result …
…STeve - KF5VH
Try this approach:
asterisk -rx “rpt playback $node /tmp/temp”
rm -f /tmp/temp.gsm
Note that once these audio segments are cat’ed together, a final call to
73, David KB4FXC
and
e.g.
Bob
kk6ecm
Sent from iPad
Small Problem:
Skyler
Bob
kk6ecm
Sent from iPad
I tried stuff like
Skyler KDØWHB\
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
