WA1NVC
1
I want to play a message with a macro e.g. (1234)
in rpt.conf I have
macro=macro
[macro]
1234=cmd,/usr/bin/command.sh
I can execute the command and play the message successfully at the bash prompt with
/usr/bin/command.sh
From the CLI> prompt the following does NOT work
CLI> rpt fun *51234
What am I missing?
Roger
WA1NVC
N5LSN
2
The asterisk user has to have permission to run the script.
Manually run the script as the asterisk user and see if it works:
sudo -u asterisk /usr/bin/command.sh
WA3WCO
3
You may also want to review ASL3 Manual: Permissions
WA1NVC
4
What is the correct way to play a voice message using DTMF?
Obviously I am not doing it right as what I did does not work.
Roger
WA1NVC
N5LSN
5
1234=localplay,/path/to/sound/file
Then *1234
