Permanent Connections via Terminal
Hello,
Is it possible to create a permanent node connection via the Terminal or even better via DTMF or must you use the Allmon3 console to do it.
Package Version
allmon3 1.5.1-1.deb12
asl3 3.8-1.deb
asl3-asterisk 2:22.4.1+asl3-3.5.4-1.deb12
asl3-asterisk-config 2:22.4.1+asl3-3.5.4-1.deb12
asl3-asterisk-modules 2:22.4.1+asl3-3.5.4-1.deb12
asl3-menu 1.14-1.deb12
cockpit 287.1-0+deb12u3
cockpit-pcp 287.1-0+deb12u3
cockpit-ws 287.1-0+deb12u3
dahdi 1:3.1.0-2
dahdi-dkms 1:3.4.0-6+asl
dahdi-linux 1:3.4.0-6+asl
Ignore me, I found it, sorry...
Just for the record in the case folks stumble on this later,
There is nothing allmon or any manager can do that you can not do from the command line. For they are issuing commands in the same way.
