I’ve read the Wiki about this and get it but what I’m wondering about is I have 2 “satellite” nodes that I want perm connected to a “hub” node. As such, I need the startup Macro on the hub to call 2 different macros?
Under functions stanza:
999=ilink,13 ; Permanent link transceive
startup_macro=*999<1st node>*999<2nd node>#
Is that correct?
And I assume the code checks for an active connection to the nodes selected every so often and if not connected, it reconnects?
