I have a Clearnode operating on a Starlink ISP. I have initiated a 44Net Wireguard tunnel to an Ubuntu Server on my local network and routed the tunnel to that server. I added iptables to route the tunnel traffic over to the Clearnode ip address on port 4569. I have pinged through the system from the WAN via the tunnel and then to the Clearnode to verify the paths are functioning. However, when I use "asterisk -rx "rpt show registrations" the perceived IP is Starlink, not the tunnel.
44Net Connect shows the tunnel connected and passing traffic. I can see the traffic on my server.
AI thinks I should be able to get on Allstarlink.org and assign the tunnel ip to my server but the only place I can see for this is the "proxy address" box in the server settings. I tried it but it didn't work.
How do I get Allstarlink servers to route my traffic to the tunnel? I only need the "connect requests" coming in from the internet to reach port 4569 of the Clearnode so that my friends can connect to my node.
You don't assign it. It's perceived as labeled. Look at rpt show registrations and it should show your 44Net Connect IP. If it doesn't, then your tunnel routing isn't working correctly for HTTP and IAX.
Ok, that was my impression in that the Allstarlink server would see the WAN ip address. So if the Allstarlink server is perceiving my WAN address and not the Tunnel's address, then it's because the node is not being presented on the Tunnel.
The implementation of the Wireguard tunnel on a separate server (which is what I've done) does not present an actual node to the tunnel, only packets being relayed on the local network between the interposing server and the node. So now I'm questioning whether an interposing server can actually work. The iptable rules I'm using on the server are meant to identify packets to and from the node via the 4569 port and those are to be routed via the server in and out the tunnel.
Most of the guidance I am seeing deals with implementing the Wireguard tunnel on the actual machine serving ASL3 and Asterisk. In the case of the Clearnode device, Node-Ventures maintains templates that overwrite configuration files with their own data and thus I am concerned that it may be useless to try to load and implement Wireguard on the node itself. I did talk to the proprietor of Node-Ventures about it and he said to try it and see if it works. But the alternate possible solution of using a different server on the local network as a sub-router for the Clearnode basically removes any need of altering the configuration of the Clearnode. That is why I have tried it.
I have not found anyone yet who has managed to implement the 44Net Connect and Wireguard tunnel on the Clearnode. If you know of anyone or know of it yourself, please let me know. In addition to that, I only have experience forwarding ports with rules through common routers and no experience with Tunnels or Wireguard at all. This is a learning experience for me.
The Clearnode itself shows the WAN ip to be the Starlink WAN address. In the way I have configured the system, the Clearnode should actually be seeing the Ubuntu Server ip as it's WAN address. Wouldn't that make sense?
You would need the Wireguard tunnel on your next-hop device. If it's a Clearnode connected directly to a Starlink, that won't work very well. You could do a regular node on a Starlink or you'd have to put something in the middle and deal with a double-NAT situation.
No. If the Clearnode is registering directly over it's default route, and the next hop default route is a Starlink, Starlink it what will be seen.
What it sounds like you want to do is make your clearnode a private node, make your Ubuntu Server a hub, connect your Clearnode to the Ubuntu hub as a private connection and then have people connect to your hub node.
Actually, my intent was to continue to use the Clearnode and its fancy iphone app because it's so convenient. The Wireguard tunnel was an attempt to get around the Starlink mess. I had previously tried operating Starlink on bypass direct to my own router where I could simply port forward 4569. I could not get it to work even though I upgraded my Startlink subscription to provide me with a single WAN ip address. But my next action if I cannot get this to work would be to drag out one of my spare Raspberry Pi's, implement it as an ASL node, and use the nice instructions in the Allstarlink manual to implement Wireguard....the point being I would have a better chance of having a node that other hams could connect to....I don't have that right now.
So it looks like ASL3 uses the HTTPS POST sent to register.allstarlink.org to determine the node's ip address by inspecting the Layer 3 TCP/IP packet. So if Wireguard is installed on the node itself, this "perceived" address would be the Tunnel IP. Otherwise, the HTTPS POST that is sent every 3 minutes would have to be intercepted and edited...I don't think that's going to happen. If Allstartlink had a method of bypassing this 'perceived' IP address and could accept a assigned IP, methods similar to the one I am experimenting with could be made to work.
There are probably plenty of good reasons why Allstarlink does it in this way and I don't pretend to know what all those reasons are. But I think I am wasting my time trying to Tunnel from a machine that is not a node. Live and learn...
Just make sure your marking and forwarding your traffic for UDP/4569 and your local UDP port if you're using something different than the default 4569. Also, disable statposting because it'll never work since your HTTP-based IP and IAX-based IP will never match.
Node-ventures (Clearnode people) are working specifically on a fix to get outbound on a starlink service. Check the website for updates!
I use Mikrotik or the Gl-inet SFT-1200 (easier) routers for 44net. I put one on a starlink router and it tunneled right through with no problems... it did inbound just fine, too!
You would need to register and verify your callsign on portal.ampr.org, apply for the addresses and set up the router...
I have been using these for years!
There is significant ongoing work right now to replace the entire IP-based connection system with a key-based system that will avoid the carrier grade NAT problem entirely and support IPv6. Unfortunately, doing it correctly and future proofing it while also trying to contemplate people who are refusing to upgrade their nodes will take time still.
Node-Ventures has a shared IP tunnel already available for any ClearNode users who are experiencing CGNAT issues - contact [email protected] and we’ll get you set up !
Hi Gerry, as we already discussed, my only issue is with other hams not being able to connect with me. You mentioned that your shared IP tunnel would not help with that.
I have never experienced and issue with getting outbound connections through Starlink. The issue is allowing inbound connections. Even when I upgraded Startlink to a commercial account with an assigned IP address and installed a third-party router, I still could not get incoming connections even with port 4569 forwarded to the Clearnode.
I have already had a Tunnel at 44Net. I used a Linux server I have on my network to provide my end of the Wireguard tunnel and then routed the packets in and out on port 4569 to or from the Clearnode local IP. This is now functioning correctly with all firewalls in place. Connections coming in from the WAN are now routed to the Clearnode and connecting properly. After I started this post I was able to get it all working by changing the Clearnode gateway to my Linux Server instead of the Starlink router.
