There is plenty to know on this subject and I have not got to the
bottom of it all…LOL
Parrot is used most commonly for instant tests by DTMF user
command.
(must be enabled as parrot once by command )
AND
On simplex nodes where everything is rec/played-back (creates
delay)
I have been told it does not work on headless nodes BUT…
I see no reason for that, but it could be.
After testing it myself and unable to make it work as a headless
VPS node,
I wrote my own script to do the same on connect.
But in making that work, I found my install from iso of ASL 1.01
had errors in the modules.conf name spelling,
so my temporary belief of what I was told about it not working
headless should be tested again. (perhaps I will when time
allows).
You should be able to attach this to a public or private node if
it does indeed work headless.
Double check that all the correct modules are being loaded and
they are spelled correctly in the module list or they will not
load for you.
Sorry, this is all the time I have to throw at it right now, but
let me know if you run into a specific problem.
But I would also be curious of your success !
…mike/kb8jnm
On 6/27/2018 4:36 PM, wrote:
kc8qch@gmail.com
Good Afternoon/evening/morning to everyone,
Tell me about parrot mode. I am
trying to play around with it and have read what I have found
online, but I am still not clear on a few things:
Does it
only work on the node it is active for or could the node be
connected to another node and used on that node? For
example. Node A has Parrot mode turned on. It is connected
to node B. Can you transmit on Node B and have Node A parrot
what it heard back?
Does it
only work over the radio or can it be used on a radio less
node?
I am trying to set one up on a
private node vs a public node so I can move it around as
needed in my own network for testing things. I am just trying
to understand the mode more is all.
Jeff
Jeff Lehman,
KC8QCH
Email:
Webmaster
Hamilton County
ARPSC
Email:
Allstar Node 47374
Administrator
The Guild/IRN
kc8qch@gmail.com
http://www.hamcoarpsc.org
hamcoarpsc@gmail.com
http://theguildglobal.org
