outstreamcmd, ezstream, and error: manager.c: Unable to bind socket: Address already in use
After setting up the outstreamcmd parameter in rpt.conf with ezstream on my DIAL AllStar node I noticed that when I stopped and restarted the asterisk service, I was getting the following error in the log:
[Oct 29 23:15:37] WARNING[19838] manager.c: Unable to bind socket: Address already in use
I found that after a service asterisk stop, port 5038 was still in use.
my manager.conf file has port = 5038
prior to a service asterisk stop - I get the following:
root@Server1:~# ps -ef | grep 7497
root 7497 1 24 13:45 ? 00:09:24 /usr/sbin/asterisk
root 7528 7497 0 13:45 ? 00:00:00 /bin/sh -c /usr/bin/lame --preset cbr 16 -r -m m -s 8 --bitwidth 16 - - | /usr/bin/ezstream -qvc /etc/asterisk/ezstream.xml
after a service asterisk stop I can still see port 5038 in use:
root@Server1:~# netstat -nlp|grep 5038
tcp 0 0 127.0.0.1:5038 0.0.0.0:* LISTEN 7528/sh
Now, when I issue asterisk service start I get the following error:
and Asterisk fails to load
If I kill pid 7528 then my service asterisk start works fine.
I assume outstreamcmd is using manager, shells out to ezstream which is a child of asterisk, and when asterisk shuts down, the process running ezstream is left running.
Should I put something in my asterisk startip script to look for processes using 5038 and kill them?
-Larry
Make sure asterisk is stopping.
kill it if necessary
killall -9 /usr/sbin/asterisk
On 11/01/2015 08:34 AM, Larry da Ponte
still in use.
        root � � �7497 � � 1 24 13:45 ? � � � �00:09:24
/usr/sbin/asterisk
        root � � �7528 �7497 �0 13:45 ? � � � �00:00:00 /bin/sh
    • | /usr/bin/ezstream -qvc /etc/asterisk/ezstream.xml
use:
tcp � � � �0 � � �0 127.0.0.1:5038 � � � �
�0.0.0.0:* � � � � � � � LISTEN � � �7528/sh
following error:
fine.
-Larry
1st Law of Logic
