Numerous kernal errors in log
While looking in the log for another issue, I noticed this error is occurring almost every second:
kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
Any idea what is causing this error and/or how to fix it?
That’s the Broadcom wireless driver. I see errors from it every few hours on RPi 3B+. I’m not sure why you’re at 1/sec unless there’s something quite upsetting to the wireless link.
Broadcom firmware is proprietary…that’s the best I can answer “how to fix?”. So check config, etc. or try reinstalling the driver.
https://wiki.debian.org/brcmfmac
Interesting… I’m using a RPi 4 connected via Ethernet so never setup the WiFi. I need to check my HamVoIP node to see if it has the same error.
You can disable/enable wireless using sudo rfkill toggle wlan and see if that quiets things down.
EDIT: If necessary, install rfkill with sudo apt install util-linux
That can mean a number of things from WiFi signal interference to your WiFi chip is dying. If you aren’t using WiFi, try turning it off completely and see if that silences the error.
I looked at one of my ASL3 nodes that doesn’t use WiFi, and i have the same thing upon setting the WiFI country but setup no configuration:
[188456.466202] brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
[188456.570186] brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
[188456.674204] brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
[188551.354441] brcmfmac: brcmf_set_channel: set chanspec 0xd022 fail, reason -52
[188551.462432] brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
[188551.566431] brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
[188551.670432] brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
I added the following at the end of /boot/firmware/config.txt to completely disable the WiFi chip:
[all]
dtoverlay=disable-wifi
I recreated it by logging in from console and ifconfigging wlan0 down, then up - even with a configured wifi network and a configured country, it generates the errors until the connection sets up.
