I have an Allstar node connected to a repeater that recently went down due to a bad SD card. I didn’t do the original setup on the configuration and the ham that did ultimately didn’t make a backup. I have a new SD card and have loaded the Allstar image and completed the updates. The Pi/USB sound card is now controlling the repeater as expected. However, when I try to log into the Pi via supermon, I get the web page just fine but when I enter user/password I get “48653 not found in our allmon ini file.”
I’ve tried everything I can think of but haven’t had any luck.
With Allmon there is a file in /var/www/html/allmon/allmon.ini.php that needs to be configured. But I’m not sure how Supermon does it. Maybe the same. Take a look for allmon.ini.sample and rename and configure.
Problem resolved. I saw in the readme that an exclamation mark is a no-no in the password. I removed it, updated it in the respective locations and it took off.
