I am new to Linux after about 20 yrs away from programming on it. I installed the image cleanly and was able to logon and change the password, set a new hostname, and a static IP to match port forwarding on my firewall. I then get prompted
to enter my Allstar id and password…that’s the point I cannot get past. I am registered and online on the website fine, my node shows up in a greyed out box in the all nodes list. But on the DIAL install, I enter my id and password ankeep getting prompter
to reenter the password over & over until it fails. I have tried using my website ID and password combo, the node and website password combo, the node and pin combo, nothing works and it is the same, the system reprompts for the password adinifnitum.
I have reinstall the DIAL at least 10 times so far and reached a level of frustration as to where to go next…help!
If you have a node number you should be logged in and see on the top bar node, click that then node configuration. Then click your node. You password will be in thr yellow box below.
Use the same login you use to login to the Portal. The call sign is
in caps, (at least mine is).
73, Steve N4IRS
On 11/30/2015 10:09 PM, Greg Mohr
from programming� on it.� I installed the image cleanly and
and a static IP to match port forwarding on my firewall.� I
then get prompted to enter my Allstar id and password�that�s
the point I cannot get past.� I am registered and online on
all nodes list.� But on the DIAL install, I enter my id and
password ankeep getting prompter to reenter the password over
& over until it fails.� I have tried using my website ID
next�help!
Thank you
Greg
1st Law of Logic
