Noob als 3 using home built rpg node
Hi guys
Please can you help me i purchased a pre-modded cm108 board,resistors removed and the capacitor it is the no transistor version, rpi 3 and using beofeng 888 set up as in YT videos can u please can you advise what the settings need to be in terminal as all the videos i can find are old and i am having problems with audio tx and rx also in allmon 3 node is showing transmit local source if thats any help
M7MJW (kevin)
I found this:
Hopefully the shipping is cheaper within the UK…
If the link doesn’t post properly, search “CM108 Sound FOB Allstar node”
thanks thats the one i purchased finally got it working but on parrot audio is very low and rx audio is at 999
