This issue is similar to at least two other posts but with significant differences.
We have a rather strange issue on three nodes and three others in the group have a similar problem.
rpt cmd 58nnn1 ilink 3 55553 ; connects properly from CLI
*806 ; from mic keypad disconnects properly
*155553 ; from mic keypad disconnects properly
rpt cmd 58nnn1 ilink 1 55553 ; disconnects properly from CLI
rpt fun 58nnn1 *155553 ; disconnects properly from CLI
; transmit and receive is identified as
; proper from the parrot site.
*815 ; reports status properly
rpt fun 58nnn1 *355553 ; does NOT connect from CLI
; it simply shows next CLI command line.
*355553 ; does NOT connect from mic keypad
; CLI shows proper decoding
Call into 58nnn1 ; from other nodes works properly.
Call into 58nnn1 ; from iPhone Repeater Phone works properly.
Everything appears to work normally, except the *3 function. Apparently, something is amiss in rpt.conf [functions] stanza. Mandatory command codes show ‘3 = ilink,3’.
We have rebuilt three different nodes, with 3 different Raspberry Pi 3B+, three different RL-20 boards, and three different SD cards with three different images. The setups use XYL’s NNX node registration on one, and two different NNX node numbers &servers from my call. All behave the same.
Each test is with a single node behind the router. The Calix router on the fiber-optic cable has been replaced.
Thank you for the quick response.
Yes that update is installed.
This is the CLI response using rpt fun:
node58nnn1*CLI> rpt fun 58nnn1 355553
node58nnn1CLI> rpt fun 58nnn1 355553
node58nnn1CLI>
Another observation when entering from the mic DTMF keypad.
CLI shows decode properly for *35555, but does not decode the last 3.
If trying to connect to a 6 digit NNX, it does not decode the last two digits.
It appears to decode 4-digits, but not five or six.
The RL-20 board shows it is hung up with the COS light staying on for about a minute. Keying does not break the hang-up.
I appreciate your efforts to decipher this.
ASL3 install is so fabulous compared to older ASL2 and brandX.
Connected to Asterisk 20.9.1+asl3-3.0.4-1.deb12 currently running on node58nnn1 (pid = 4081)
node58nnn1CLI>
I notice that the * is deleted and font goes to italic when paste as text. Try again.
node58nnn1CLI>
"node58nnn1*CLI> rpt fun 58nnn1 355553"
"node58nnn1CLI> rpt fun 58nnn1 355553"
"node58nnn1CLI> "
Interesting.
The editor responds to the * before the remote node by dropping it, then converts the digits font to italics.
The next lines lose its asterisk even before the CLI and the remote node number.
It looks normal on entry, but when reply, the post is reformated.
node58nnn1*CLI> core set debug 4 app_rpt.so
Core debug was 0 and has been set to 4 for 'app_rpt'.
node58nnn1*CLI> rpt fun 58nnn1 *355553
node58nnn1*CLI>
Interesting. No response here, nothing in logs, nothing in diagnostic reports. Did I miss something?
I can confirm that in normal/stock configurations this works just fine:
node460181*CLI> rpt fun 460181 *348496
node460181*CLI> rpt nodes 460181
************************* CONNECTED NODES *************************
T43211, T45839, T47735, T48496, T527250, T535071, T545661, T54610
T55735, T574079, T58751
Have you customized something in rpt.conf or extensions.conf? I also note that core set debug 4 app_rpt.so seems to have no output for me either.
These are the changes in rpt.conf to activate the COS LED on the RL-20 board.
events=events ;MOD remove comment to activate events stanza
961 = cop,62,GPIO8=1 ; MOD Send message to GPIO pin8 - turn on COS LED
962 = cop,62,GPIO8=0 ; MOD Send Message to GPIO pin8 - turn off COS LED
[events]
;;;;; Events Management ;;;;;
;status,2 = c|f|RPT_NUMLINKS ; Say time of day when all links disconne>
58nnn1,*961 = f|t|RPT_RXKEYED ; MOD Trigger COS when R>
58nnn1,*962 = f|f|RPT_RXKEYED ; MOD Release COS when R>
I note all changes by a comment with my initials, so I can track changes.
This is corresponding change in simpleusb.conf
[58nnn1](node-main)
gpio8 = out0 ; MOD COS LED
I appreciate that *3 obviously worked in some systems since it was released.
Not only my three nodes but others in our group are encountering similar issues, ie
can connect with Allmon or rpt cmd, but not rpt fun.
One of those does not have the COS commands and was not aware.
I will make a complete new image and update the results.
In meantime, we will retry the console debug suggestion.
Thanks for all the suggestions. We surely appreciate all the time and energy helping us resolve the problem.
