k4sip
#1
The nodeList.php function underneath Maps on the Stats page has not been linking properly for a little while now.
e.g. http://stats.allstarlink.org/maps/nodeList.php?node=47363
Steps to reproduce:
- Go to Allstar Map
- Narrow in on a node and click on numeric ID hyperlink
- File not found. error appears.
Just reporting it here so it’s on the record. (Did not find a related remark in the search.)
Byron
wd6awp
#2
I’ll look into it. As far as you know, did this used to work?
In the mean time… Node 47363 works.
k4sip
#3
I know that other method works.
I was just trying to get it recognized so its fixed in the interface for benefit of others.
It’s been broken for about the past 2 years I gather.
Byron
wd6awp
#4
This has been fixed. The js now points to the correct link noted above. Your browser cache may have to clear before it works.
k4sip
#5
Perfecto! Thanks and take care.
Byron
system
Closed
#6
