Node67128 not showing in the Nodelist
OS Kernel : 6.12.62+rpt-rpi-v8
ASL [app_rpt] : 3.7.1
My node 67128 is not showing up in the AllStar Nodelist. I’m not sure I am Registered.
AllStar registrations: │
│ "rpt show registrations" │
│ Host Username Perceived │
│ Refresh State │
│ 52.20.63.146:443 67128 │
│ 0 Not Registered │
│ 1 HTTP registration. │
│ "iax2 show registrations" │
│ Host dnsmgr Username Perceived │
│ Refresh State │
│ 52.44.147.201:4569 Y 67128 │
│ 60 Rejected │
the above text, does it look ok….
Inquiry
You are correct. Your node has not successfully registered. I would double-check that the password you have specified in the node settings matches the password from the www.allstarlink.org Portal / Node Settings page.
sudo asl-menu
  Node Settings
    AllStar Node Setup Menu
      Update node ...
        Node password
Alternatively, you can check the rpt_http_registrations.conf (or iax.conf) files. The line in the file you need to check looks like :
register => 1999:password@register.allstarlink.org
Note: the password is case sensitive
Note: it also looks like you have your system setup to register with both HTTP and IAX2. Please pick only one.
TNX, I’ve commented out the line in the iax.conf…
;register = > 67128:password@register.allstarlink.org….once this line is edited and asterisk restarted node67128 should be registared?
question concerning ; in allmon3, I can use link command to connect o node 27339, however it never show CONNECTED it show, CONNECTING…..what’s your input..???
Looking at the database, you converted 67128 into an NNX 6-digit node. So now your nodes are 671280 and 671281. Either update your node to use 671280 or edit your node to collapse it back down to a 5 digit node. As-is right now, you will never be able to use 67128.
Correct…I am GOOD now….Thanks for the info….
the only hiccup I have is “Not showing Connected” in Connect State or Mode of allmon3 Dashboard,
I’, sure you a thought or 2….
Looks like your node is online now. You'll have to wait for a bit for the chage back to a 5-digit number to propagate through the network.
