Node will not connect out (second attempt to post) PART ONE
My first post to get help was hampered by me not being able to post more than one file and emails for possible help being unable to be delivered, so I am going to try one more time. I will post my extension.conf on this post and I will make a second post and add the rpt.conf file.
The issue is on a two node pi install 47450,47452 ........ 47450 works fine 47452 will not connect out. 47452 not connecting out is what I am trying to fix.
Below l will post my extension.conf ....... I will start a new message to post rpt.conf
[general]
static = yes ; These two lines prevent the command-line interface
writeprotect = yes ; from overwriting the config file. Leave them here.
[globals]
HOMENPA = 325 ; change this to your Area Code
NODE = 47450 ; change this to your node number
NODE = 47452
[default]
exten => i,1,Hangup
[radio-secure]
;exten => ${NODE},1,rpt(${EXTEN})
exten => _XXXX!,1,NoOp(Connect from node: ${CALLERID(num)})
same => n,NoOp(Connect to: ${EXTEN})
;same => n,NoOp(The IAXPEER is ${IAXPEER(CURRENTCHANNEL)})
same => n,NoOp(The Channel IP is ${CHANNEL(peerip)})
;If channel IP eq localhost go to connect
same => n,GotoIf($["${CHANNEL(peerip)}" = "127.0.0.1"]?connect)
;If allowlist/extension dosen't exist check the denylist
same => n,GotoIf($[${DB_KEYCOUNT(allowlist/${EXTEN})} = 0]?denylist) ;goto denylist
;If allowlist/extension/callerid exists go to connect
same => n,GotoIf(${DB_EXISTS(allowlist/${EXTEN}/${CALLERID(num)})}?connect) ;goto connect
same => n,NoOp(${EXTEN} not in allowlist, Hangup)
same => n,Hangup
;If denylist/extension/callerID doesn't exist goto connect
same => n(denylist),GotoIf(${DB_EXISTS(denylist/${EXTEN}/${CALLERID(num)})}?:connect) ;don't goto connect
same => n,NoOp(${EXTEN} is in denylist, Hangup)
same => n,Hangup
same => n(connect),rpt(${EXTEN})
same => n,Hangup
[iaxrpt]
; Entered from iaxrpt in iax.conf
; Info: The X option passed to the Rpt application
; disables the normal security checks.
; Because incoming connections are validated in iax.conf,
; and we don't know where the user will be coming from in advance,
; the X option is required.
exten => ${NODE},1,rpt(${EXTEN}|X) ; NODE is the Name field in iaxrpt
[iax-client] ; for IAX VoIP clients.
exten => ${NODE},1,Ringing()
same => n,Wait(10)
same => n,Answer()
same => n,Set(CALLSIGN=${CALLERID(name)})
same => n,NoOp(Caller ID name is ${CALLSIGN})
same => n,NoOp(Caller ID number is ${CALLERID(number)})
same => n,GotoIf(${ISNULL(${CALLSIGN})}?hangit)
same => n,Playback(rpt/connected-to&rpt/node)
same => n,SayDigits(${NODE})
same => n,rpt(${NODE}|P|${CALLSIGN}-P)
same => n(hangit),NoOp(No Caller ID Name)
same => n,Playback(connection-failed)
same => n,Wait(1)
same => n,Hangup
; Comment-out the following clause if you want Allstar Autopatch service
[pstn-out]
exten => _NXXNXXXXXX,1,playback(ss-noservice)
same => n,Congestion
; Un-comment out the following clause if you want Allstar Autopatch service
;[pstn-out]
;exten => _NXXNXXXXXX,1,Dial(IAX2/allstar-autopatch/${EXTEN})
; same => n,Busy
[invalidnum]
exten => s,1,Wait(3)
same => n,Playback(ss-noservice)
same => n,Wait(1)
same => n,Hangup
[radio]
exten => _X11,1,Goto(check_route,${EXTEN},1);
exten => _NXXXXXX,1,Goto(check_route,1${HOMENPA}${EXTEN},1)
exten => _1XXXXXXXXXX,1,Goto(check_route,${EXTEN},1)
exten => _07XX,1,Goto(parkedcalls,${EXTEN:1},1)
exten => 00,1,Goto(my-ip,s,1)
[check_route]
exten => _X.,1,Noop(${EXTEN})
; no 800
exten => _1800NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1888NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1877NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1866NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1855NXXXXXX,2,Goto(invalidnum,s,1)
; no X00 NPA
exten => _1X00XXXXXXX,2,Goto(invalidnum,s,1)
; no X11 NPA
exten => _1X11XXXXXXX,2,Goto(invalidnum,s,1)
; no X11
exten => _X11,2,Goto(invalidnum,s,1)
; no 555 Prefix in any NPA
exten => _1NXX555XXXX,2,Goto(invalidnum,s,1)
; no 976 Prefix in any NPA
exten => _1NXX976XXXX,2,Goto(invalidnum,s,1)
; no NPA=809
exten => _1809XXXXXXX,2,Goto(invalidnum,s,1)
; no NPA=900
exten => _1900XXXXXXX,2,Goto(invalidnum,s,1)
; okay, route it
exten => _1NXXXXXXXXX,2,Goto(pstn-out,${EXTEN:1},1)
exten => _X.,2,Goto(invalidnum,s,1)
[my-ip]
exten => s,1,Wait(1)
same => n,SayAlpha(${CURL(http://myip.vg)})
same => n,Hangup
[allstar-sys]
exten => _1.,1,Rpt(${EXTEN:1}|Rrpt/node:NODE:rpt/in-call:digits/0:PARKED|120)
exten => _1.,n,Hangup
exten => _2.,1,Ringing
exten => _2.,n,Wait(3)
exten => _2.,n,Answer
exten => _2.,n,Playback(rpt/node)
exten => _2.,n,Saydigits(${EXTEN:1})
exten => _2.,n,Rpt(${EXTEN:1}|P|${CALLERID(name)}-P)
exten => _2.,n,Hangup
exten => _3.,1,Ringing
exten => _3.,n,Wait(3)
exten => _3.,n,Answer
exten => _3.,n,Playback(rpt/node)
exten => _3.,n,Saydigits(${EXTEN:1})
exten => _3.,n,Rpt(${EXTEN:1}|Pv|${CALLERID(name)}-P)
exten => _3.,n,Hangup
exten => _4.,1,Ringing
exten => _4.,n,Wait(3)
exten => _4.,n,Answer
exten => _4.,n,Playback(rpt/node)
exten => _4.,n,Saydigits(${EXTEN:1})
exten => _4.,n,Rpt(${EXTEN:1}|D|${CALLERID(name)}-P)
exten => _4.,n,Hangup
exten => _5.,1,Ringing
exten => _5.,n,Wait(3)
exten => _5.,n,Answer
exten => _5.,n,Playback(rpt/node)
exten => _5.,n,Saydigits(${EXTEN:1})
exten => _5.,n,Rpt(${EXTEN:1}|Dv|${CALLERID(name)}-P)
exten => _5.,n,Hangup
[allstar-public]
exten => s,1,Ringing
same => n,Set(RESP=${CURL(https://register.allstarlink.org/cgi-bin/authwebphone.pl?${CALLERID(name)})})
same => n,Set(NODENUM=${CALLERID(number)})
same => n,GotoIf($["${RESP:0:1}" = "?"]?hangit)
same => n,GotoIf($["${RESP:0:1}" = ""]?hangit)
same => n,GotoIf($["${RESP:0:5}" != "OHYES"]?hangit)
same => n,Set(CALLSIGN=${RESP:5})
;exten => s,n,GotoIf($[${DB_EXISTS(whitelist/${CALLSIGN})}]?:hangit) ; Not in whitelist
same => n,Wait(3)
same => n,Playback(rpt/node,noanswer)
same => n,Saydigits(${NODENUM})
same => n,Set(CALLERID(name)=${CALLSIGN})
same => n,Set(CALLERID(num)=0)
same => n,Rpt(${NODENUM}|X)
same => n,Hangup
same => n(hangit),Answer
same => n,Wait(1)
same => n,Hangup
#tryinclude custom/extensions.conf
Phil
Phil, while I git busy, I though you had your issue fixed, or I had you mixed up with some other help case,
Could you state what the node number is of what what you are testing a connection with.
Try some other nodes and tell us the result.
I understand the node you are connecting from with an issue is 47452
This is the status of my two node pi.......I installed 47450 on a new pi5 with ASLv3 weeks ago and i47450 works great, no problem. After weeks of 47450 working great, I installed 47452 as a second node, I went through all the steps to add 47452 in same process I did for 47450.
After the install of 47452 all appeared normal, 47452 showed up in my supermon, thus I had both 47450 and 47452 as working nodes, I could click on the bubble list for each node and it would show normal. I could use 47450 and connect to 47452 ...... worked great.
The problem arose when I tried to use 47452 to connect to any other node, I tried connecting to 47450, 55553 and a couple of friends nodes, no luck at all. While using supermon and issuing the command to connect, the screen does a little shift but there is no attempt to connect at all. The bottom line is for node 47452 it appears that all aspects of the node are in working order, but for the ability to make a connection to other nodes. It never ever shows any activity in supermon that you will see when it attempting a connection it does nothing and stays blank.
I hope this explains what is happening, If I did not give a good enought explination, please let me know what else is needed.
I can not post any files to this forum, it blocks any attempt as I am "new user", I understand there are rules for forums but how does a new user get help if he is blocked from using the forum????
Phil
Lacking ability to add files for a period of time is a basic anti-spam thing that's very common in forums. I've adjusted your account, you should be able to add attachments now.
Phil, can you post the [nodes] section of rpt.conf
thank you , I will try to behave
phil
Mike
here is the etc.conf file
;******** Template-tized rpt.conf ********
; Note to editors: set tabs to 4 space characters. No wrap to keep comments neat.
; vim: tabstop=4
; Radio Repeater configuration file for use with app_rpt ASL3
[general]
node_lookup_method = both ;method used to lookup nodes
;both = dns lookup first, followed by external file (default)
;dns = dns lookup only
;file = external file lookup only
[nodes]
; If you are using automatic update for allstar link nodes, and you probably are,
; no allstar remote nodes should be defined here. Only place a definition
; for your local nodes, and private (not on allstar directory) nodes here.
; Sample nodes on this server. These are required. Use IP 127.0.0.1
; IAX port number if not the default 4569.
;1998 = radio@127.0.0.1/1998,NONE
; Sample public or private node behind your router.
;1001 = radio@192.168.1.8:4568/1001,NONE
; Sample private node on the internet.
;1000 = radio@8.8.8.8:4569/1000,NONE
47450 = radio@127.0.0.1/47450,NONE
47452 = radio@127.0.0.1/47452,NONE
node-main
;;;;; Template for all your nodes ;;;;;
; Set the defaults for your node(s) here.
; Add your nodes below the line that says
; Add you nodes below.
;;; rxchannel ;;;
; Must also be enabled in modules.conf
; Enable the selected channel driver in modules.conf !!!
; Rx/Tx audio/signalling channel. Choose ONLY 1 per node stanza.
; rxchannel = dahdi/pseudo ; No radio (hub)
; rxchannel = SimpleUSB/1999 ; SimpleUSB
; rxchannel = Radio/1999 ; USBRadio (DSP)
; rxchannel = Voter/1999 ; RTCM device
; rxchannel = Pi/1 ; Raspberry Pi PiTA
; rxchannel = Dahdi/1 ; PCI Quad card
; rxchannel = Beagle/1 ; BeagleBoard
; rxchannel = USRP/127.0.0.1:34001:32001 ;GNU Radio interface USRP
duplex = 2 ; 0 = Half duplex with no telemetry tones or hang time.
; 1 = Half duplex with telemetry tones and hang time. Does not repeat audio.
; This mode is preferred when interfacing a repeater.
linktolink = no ; disables forcing physical half-duplex operation of main repeater while
; still keeping half-duplex semantics (optional)
linkmongain = -22 ; Link Monitor Gain adjusts the audio level of monitored nodes when a signal from another node or the local receiver is received.
; If linkmongain is set to a negative number the monitored audio will decrease by the set amount in db.
; If linkmongain set to a positive number monitored audio will increase by the set amount in db.
; The value of linkmongain is in db. The default value is 0 db.
erxgain = -3 ; Echolink receive gain adjustment
; Note: Gain is in db-volts (20logVI/VO)
etxgain = 3 ; Echolink transmit gain adjustment
;eannmode = 1 ; 1 = Say only node number on echolink connects (default = 1)
; 2 = say phonetic call sign only on echolink connects
; 3 = say phonetic call sign and node number on echolink connects
;echolinkdefault = 2 ; 0 = Telemetry output off
; 1 = Telemetry output on
; 2 = Timed telemetry output on command execution and for a short time thereafter
; 3 = Follow local telemetry mode
;echolinkdynamic = 1 ; 0 = Disallow users to change current echolink telemetry setting with a COP command
; 1 = Allow users to change the setting with a COP command
controlstates = controlstates ; system control state stanza
scheduler = schedule ; scheduler stanza
functions = functions ; Repeater Function stanza
phone_functions = functions ; Phone Function stanza
link_functions = functions ; Link Function stanza
telemetry = telemetry ; Telemetry stanza
morse = morse ; Morse stanza
wait_times = wait-times ; Wait times stanza
;inxlat = *,#,0123456789ABCD,Y ; The Y is for dialtone on function, a la CACTUS
; Rpt.conf - AllStarLink Wiki
context = radio ; dialing context for phone
callerid = "Repeater" <0000000000> ; callerid for phone calls
accountcode = RADIO ; account code (optional)
hangtime = 2000 ; squelch tail hang time (in ms) (optional, default 5 seconds, 5000 ms)
althangtime = 4000 ; longer squelch tail
totime = 180000 ; transmit time-out time (in ms) (optional, default 3 minutes 180000 ms)
idrecording = |iNOTSET ; id recording or morse string
;idtalkover = ; Talkover ID (optional) default is none
idtime = 540000 ; id interval time (in ms) (optional) Default 5 minutes (300000 ms)
politeid = 30000 ; time in milliseconds before ID timer expires to try and ID in the tail. (optional, default 30000)
;tailmessagelist=/etc/asterisk/sounds/yourtailmessage
;tailsquashedtime=900000 ; 15 minutes
;tailmessagetime=21600000 ; 6 hours (200000000 ms, 55.5555 hours is the max value possible)
unlinkedct = ct2 ; Send a this courtesy tone when the user unkeys if the node is not connected to any other nodes. (optional, default is none)
remotect = ct3 ; remote linked courtesy tone (indicates a remote is in the list of links)
linkunkeyct = ct8 ; sent when a transmission received over the link unkeys
;nolocallinkct = 0 ; Send unlinkedct instead if another local node is connected to this node (hosted on the same PC).
;connpgm = yourconnectprogram ; Disabled. Execute a program you specify on connect. (default)
; passes 2 command line arguments to your program:
; 1. node number in this stanza (us)
; 2. node number being connected to us (them)
;discpgm = yourdisconnectprogram ; Disabled. Execute a program you specify on disconnect. (default)
; 2. node number being disconnected from us (them)
;events=events ; Events Management Event Management - AllStarLink Wiki
;lnkactenable = 0 ; Set to 1 to enable the link activity timer. Applicable to standard nodes only.
;lnkacttime = 1800 ; Link activity timer time in seconds.
;lnkactmacro = *52 ; Function to execute when link activity timer expires.
;lnkacttimerwarn = 30seconds ; Message to play when the link activity timer has 30 seconds left.
;remote_inact_timeout = ; Specifies the amount of time without keying from the link. Set to 0 to disable timeout. (15 * 60)
;remote_timeout = ; Session time out for remote base. Set to 0 to disable. (60 * 60)
;remote_timeout_warning_freq = ; 30
;remote_timeout_warning = ; (3 * 60)
;nounkeyct = 0 ; Set to a 1 to eliminate courtesy tones and associated delays.
holdofftelem = 0 ; Hold off all telemetry when signal is present on receiver or from connected nodes
; except when an ID needs to be done and there is a signal coming from a connected node.
telemnomdb = -3 ; Telemetry Nominal Amplitude reference in dB
telemduckdb = -15 ; Telemetry Ducking in dB when local or link voice tx in progress
telemdefault = 2 ; 0 = telemetry output off
; 1 = telemetry output on (default = 1)
; 2 = timed telemetry output on command execution and for a short time thereafter.
telemdynamic = yes ; yes = disallow users to change the local telemetry setting with a COP command
; 1 = Allow users to change the setting with a COP command. (default = 1)
;beaconing = 0 ; Send ID regardless of repeater activity (Required in the UK, but probably illegal in the US)
parrotmode = 0 ; 0 = Parrot Off (default = 0)
; 1 = Parrot On Command
; 2 = Parrot Always
; 3 = Parrot Once by Command
parrottime = 1000 ; Set the amount of time in milliseconds
; to wait before parroting what was received
;rxnotch=1065,40 ; (Optional) Notch a particular frequency for a specified
; b/w. app_rpt must have been compiled with
; the notch option
;startup_macro = ; Best use in your node stanza (below) when more than one node
;nodenames = /var/lib/asterisk/sounds/rpt/nodenames.callsign ; Point to alternate nodename sound directory
; *** Status Reporting ***
; Uncomment the statpost line to report the status of your node to stats.allstarlink.org
;statpost_url = http://stats.allstarlink.org/uhandler ; Status updates
;;; End of node-main template
;;;;;;;;;;;;;;;; Configure your nodes here ;;;;;;;;;;;;;;;;
; Note: there is no need to duplicate entire settings. Only
; place settings that are different than the template.
47450
idrecording = |iAG5EY
duplex = 1
hangtime = 400
rxchannel = SimpleUSB/47450
47452
duplex = 1
hangtime = 400
rxchannel = SimpleUSB/47452
;;;;;;;;;;;;;;;;;;; Your node settings here ;;;;;;;;;;;;;;;;;;;
link_functions = functions ; Link Function stanza;startup_macro = *8132000
;1998
;;;;;;;;;;;;;;;;;;; Another node settings here ;;;;;;;;;;;;;;;;;;;
;morse = morse_1998 ; Sample morse stanza for node 1998
[functions]
;;;;;;;;;;;;;;;;;;; functions stanza ;;;;;;;;;;;;;;;;;;;
; Prefix Functions
; *1 Disconnect Link
; *2 Monitor Link
; *3 Connect Link
; *4 Command Mode
; *5 Macros
; *6 User Functions
; *7 Connection Status/Functions
; *8 User Functions
; *9 User Functions
; *0 User Functions
; *A User Functions
; *B User Functions
; *C User Functions
; *D User Functions
;;;;;; Mandatory Command Codes ;;;;;
1 = ilink,1 ; Disconnect specified link
2 = ilink,2 ; Connect specified link -- monitor only
3 = ilink,3 ; Connect specified link -- tranceive
4 = ilink,4 ; Enter command mode on specified link
70 = ilink,5 ; System status
99 = cop,6 ; PTT (phone mode only)
;;;;; Macro Commands ;;;;;
5 = macro
;;;;; Autopatch Commands ;;;;;
; Note, This may be a good place for other 2 digit frequently used commands
;61 = autopatchup,noct = 1,farenddisconnect = 1,dialtime = 20000 ; Autopatch up
;62 = autopatchdn ; Autopatch down
; autopatchup can optionally take comma delimited setting=value pairs:
; context = string ; Override default context with "string"
; dialtime = ms ; Specify the max number of milliseconds between phone number digits (1000 milliseconds = 1 second)
; farenddisconnect = 1 ; Automatically disconnect when called party hangs up
; noct = 1 ; Don't send repeater courtesy tone during autopatch calls
; quiet = 1 ; Don't send dial tone, or connect messages. Do not send patch down message when called party hangs up
; Example: 123=autopatchup,dialtime=20000,noct=1,farenddisconnect=1
;;;;; Status Commands ;;;;;
; 1 - Force ID (global)
; 2 - Give Time of Day (global)
; 3 - Give software Version (global)
; 4 - Give GPS location info
; 5 - Last (dtmf) user
; 11 - Force ID (local only)
; 12 - Give Time of Day (local only)
721 = status,1 ; Force ID (global)
722 = status,2 ; Give Time of Day (global)
723 = status,3 ; Give software Version (global)
724 = status,4 ; Give GPS location info
725 = status,5 ; Last (dtmf) user
711 = status,11 ; Force ID (local only)
712 = status,12 ; Give Time of Day (local only)
;;;;; Link Commands ;;;;;
; 1 - Disconnect specified link
; 2 - Connect specified link -- monitor only
; 3 - Connect specified link -- tranceive
; 4 - Enter command mode on specified link
; 5 - System status
; 6 - Disconnect all links
; 7 - Last Node to Key Up
; 8 - Connect specified link -- local monitor only
; 9 - Send Text Message (9,<destnodeno or 0 (for all)>,Message Text, etc.
; 10 - Disconnect all RANGER links (except permalinks)
; 11 - Disconnect a previously permanently connected link
; 12 - Permanently connect specified link -- monitor only
; 13 - Permanently connect specified link -- tranceive
; 15 - Full system status (all nodes)
; 16 - Reconnect links disconnected with "disconnect all links"
; 17 - MDC test (for diag purposes)
; 18 - Permanently Connect specified link -- local monitor only
;;;;; ilink commands ;;;;;
; commands 1 through 5 are defined in the Mandatory Command section
; 806 = ilink,6 ; Disconnect all links
; 807 = ilink,7 ; Last Node to Key Up
; 808 = ilink,8 ; Connect specified link -- local monitor only
; 809 = ilink,9,1999,"Testing" ; would send a text message to node 1999 replace 1999 with 0 for all connected nodes
; 810 = ilink,10 ; Disconnect all RANGER links (except permalinks)
; 811 = ilink,11 ; Disconnect a previously permanently connected link
; 812 = ilink,12 ; Permanently connect specified link -- monitor only
; 813 = ilink,13 ; Permanently connect specified link -- tranceive
; 815 = ilink,15 ; Full system status (all nodes)
; 816 = ilink,16 ; Reconnect links disconnected with "disconnect all links"
; 817 = ilink,17 ; MDC test (for diag purposes)
; 818 = ilink,18 ; Permanently Connect specified link -- local monitor only
;;;;; Control operator (cop) functions. ;;;;;
;Change these to something other than these codes listed below!
;901 = cop,1 ; System warm boot
;902 = cop,2 ; System enable
;903 = cop,3 ; System disable
;904 = cop,4 ; Test tone on/off (toggle)
;905 = cop,5 ; Dump system variables on console (debug use only)
;907 = cop,7 ; Time out timer enable
;908 = cop,8 ; Time out timer disable
;909 = cop,9 ; Autopatch enable
;910 = cop,10 ; Autopatch disable
;911 = cop,11 ; User linking functions enable
;912 = cop,12 ; User linking functions disable
;913 = cop,13 ; Query system control state
;914 = cop,14 ; Set system control state
;915 = cop,15 ; Scheduler enable
;916 = cop,16 ; Scheduler disable
;917 = cop,17 ; User functions enable (time, id, etc)
;918 = cop,18 ; User functions disable
;919 = cop,19 ; Select alternate hang time (althangtime)
;920 = cop,20 ; Select standard hangtime (hangtime)
;921 = cop,21 ; Enable Parrot Mode
;922 = cop,22 ; Disable Parrot Mode
;923 = cop,23 ; Birdbath (Current Parrot Cleanup/Flush)
;924 = cop,24 ; Flush all telemetry
;925 = cop,25 ; Query last node un-keyed
;926 = cop,26 ; Query all nodes keyed/unkeyed
;930 = cop,30 ; Recall Memory Setting in Attached Xcvr
;931 = cop,31 ; Channel Selector for Parallel Programmed Xcvr
;932 = cop,32 ; Touchtone pad test: command + Digit string + # to playback all digits pressed
;933 = cop,33 ; Local Telemetry Output Enable
;934 = cop,34 ; Local Telemetry Output Disable
;935 = cop,35 ; Local Telemetry Output on Demand
;936 = cop,36 ; Foreign Link Local Output Path Enable
;937 = cop,37 ; Foreign Link Local Output Path Disable
;938 = cop,38 ; Foreign Link Local Output Path Follows Local Telemetry
;939 = cop,39 ; Foreign Link Local Output Path on Demand
;942 = cop,42 ; Echolink announce node # only
;943 = cop,43 ; Echolink announce node Callsign only
;944 = cop,44 ; Echolink announce node # & Callsign
;945 = cop,45 ; Link Activity timer enable
;945 = cop,46 ; Link Activity timer disable
;947 = cop,47 ; Reset "Link Config Changed" Flag
;948 = cop,48 ; Send Page Tone (Tone specs separated by parenthesis)
; 949 = cop,49 ; Disable incoming connections (control state noice)
; 950 = cop,50 ; Enable incoming connections (control state noicd)
; 951 = cop,51 ; Enable sleep mode
; 952 = cop,52 ; Disable sleep mode
; 953 = cop,53 ; Wake up from sleep
; 954 = cop,54 ; Go to sleep
; 955 = cop,55 ; Parrot Once if parrot mode is disabled
; 956 = cop,56 ; Rx CTCSS Enable
; 957 = cop,57 ; Rx CTCSS Disable
; 958 = cop.58 ; Tx CTCSS On Input only Enable
; 959 = cop,59 ; Tx CTCSS On Input only Disable
; 960 = cop,60 ; Send MDC-1200 Burst (cop,60,type,UnitID[,DestID,SubCode])
; Type is 'I' for PttID, 'E' for Emergency, and 'C' for Call
; (SelCall or Alert), or 'SX' for STS (ststus), where X is 0-F.
; DestID and subcode are only specified for the 'C' type message.
; UnitID is the local systems UnitID. DestID is the MDC1200 ID of
; the radio being called, and the subcodes are as follows:
; Subcode '8205' is Voice Selective Call for Spectra ('Call')
; Subcode '8015' is Voice Selective Call for Maxtrac ('SC') or
; Astro-Saber('Call')
; Subcode '810D' is Call Alert (like Maxtrac 'CA')
; 961 = cop,61 ; Send Message to USB to control GPIO pins (cop,61,GPIO1=0[,GPIO4=1].....)
; 962 = cop,62 ; Send Message to USB to control GPIO pins, quietly (cop,62,GPIO1=0[,GPIO4=1].....)
; 963 = cop,63 ; Send pre-configred APRSTT notification (cop,63,CALL[,OVERLAYCHR])
; 964 = cop,64 ; Send pre-configred APRSTT notification, quietly (cop,64,CALL[,OVERLAYCHR])
; 965 = cop,65 ; Send POCSAG page (equipped channel types only)
; [functions-remote]
;;;;; Functions for remote bases ;;;;;
; 0 = remote,1 ; Retrieve Memory
; 1 = remote,2 ; Set freq.
; 2 = remote,3 ; Set tx PL tone
; 3 = remote,4 ; Set rx PL tone
; 40 = remote,100 ; Rx PL off
; 41 = remote,101 ; Rx PL on
; 42 = remote,102 ; Tx PL off
; 43 = remote,103 ; Tx PL on
; 44 = remote,104 ; Low Power
; 45 = remote,105 ; Medium Power
; 46 = remote,106 ; High Power
; 711 = remote,107 ; Bump -20
; 714 = remote,108 ; Bump -100
; 717 = remote,109 ; Bump -500
; 713 = remote,110 ; Bump +20
; 716 = remote,111 ; Bump +100
; 719 = remote,112 ; Bump +500
; 721 = remote,113 ; Scan - slow
; 724 = remote,114 ; Scan - quick
; 727 = remote,115 ; Scan - fast
; 723 = remote,116 ; Scan + slow
; 726 = remote,117 ; Scan + quick
; 729 = remote,118 ; Scan + fast
; 79 = remote,119 ; Tune
; 51 = remote,5 ; Long status query
; 52 = remote,140 ; Short status query
; 67 = remote,210 ; Send a *
; 69 = remote,211 ; Send a #
; 91 = remote,99,CALLSIGN,LICENSETAG ; Remote base login.
; Define a different dtmf sequence for each user which is
; authorized to use the remote base to control access to it.
; For examble 9139583=remote,99,WB6NIL,G would grant access to
; the remote base and announce WB6NIL as being logged in.
; Another entry, 9148351=remote,99,WA6ZFT,E would grant access to
; the remote base and announce WA6ZFT as being logged in.
; When the remote base is disconnected from the originating node, the
; user will be logged out. The LICENSETAG argument is used to enforce
; tx frequency limits. See [txlimits] below.
; 85 = cop,6 ; Remote base telephone key
[telemetry]
;;;;; Telemetry ;;;;;
; Telemetry entries can be shared across all repeaters, or defined for each repeater.
; Can be a tone sequence, morse string, or a file
; |t - Tone escape sequence
; Tone sequences consist of 1 or more 4-tuple entries (freq1, freq2, duration, amplitude)
; Single frequencies are created by setting freq1 or freq2 to zero.
; |m - Morse escape sequence
; Sends Morse code at the telemetry amplitude and telemetry frequency as defined in the
; [morse] section.
; Follow with an alphanumeric string
; |i - Morse ID escape sequence
; Sends Morse code at the ID amplitude and ID frequency as defined in the
; [morse] section.
ct1 = |t(350,0,100,2048)(500,0,100,2048)(660,0,100,2048)
ct2 = |t(660,880,150,2048)
ct3 = |t(440,0,150,4096)
ct4 = |t(550,0,150,2048)
ct5 = |t(660,0,150,2048)
ct6 = |t(880,0,150,2048)
ct7 = |t(660,440,150,2048)
ct8 = |t(700,1100,150,2048)
ct9 = |t(1633,0,50,1000)(0,0,30,0)(1209,0,50,1000);
ranger = |t(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,150,0)
remotemon = |t(1209,0,50,2048) ; local courtesy tone when receive only
remotetx = |t(1633,0,50,3000)(0,0,80,0)(1209,0,50,3000) ; local courtesy tone when linked Trancieve mode
cmdmode = |t(900,903,200,2048)
functcomplete = |t(1000,0,100,2048)(0,0,100,0)(1000,0,100,2048)
remcomplete = |t(650,0,100,2048)(0,0,100,0)(650,0,100,2048)(0,0,100,0)(650,0,100,2048)
pfxtone = |t(350,440,30000,3072)
patchup = rpt/callproceeding
patchdown = rpt/callterminated
; As far as what the numbers mean,
; (000,000,010,000)
; | | | |-------amplitude
; | | |-------------duration
; | |-------------------Tone 2
; |-------------------------Tone 1
; So, with 0,0,10,0 That says No Tone1, No Tone2, 10ms duration, 0 Amplitude.
; Use it for a delay. Fine tuning for how long before telemetry is sent, in conjunction with the telemdelay parameter)
; The numbers, like 350,440,10,2048 are 350Hz, 440Hz, 10ms delay, amplitude of 2048.
[morse]
;;;;; Mores code ;;;;;
; Morse code parameters, these are common to all repeaters.
speed = 20 ; Approximate speed in WPM
frequency = 800 ; Morse Telemetry Frequency
amplitude = 4096 ; Morse Telemetry Amplitude
idfrequency = 1065 ; Morse ID Frequency
idamplitude = 1024 ; Morse ID Amplitude
;[morse]
;speed = 35 ; Not leagle in the USA
;frequency = 800 ; Morse Telemetry Frequency *Changed
;amplitude = 4096 ; Morse Telemetry Amplitude
;idfrequency = 750 ; Morse ID Frequency *Changed
;idamplitude = 512 ; Morse ID Amplitude *Changed
[wait-times]
; A section for wait times can be defined for every repeater
telemwait = 2000 ; Time to wait before sending most telemetry
idwait = 500 ; Time to wait before starting ID
unkeywait = 2000 ; Time to wait after unkey before sending CT's and link telemetry
calltermwait = 2000 ; Time to wait before announcing "call terminated"
[wait-times_hd]
; Sample for half-duplex
telemwait = 100 ; Time to wait before sending most telemetry
idwait = 100 ; Time to wait before starting ID
unkeywait = 100 ; Time to wait after unkey before sending CT's and link telemetry
[memory]
;;;;; Remote base memories ;;;;;
; Memories for remote bases (not for repeaters or hotspots). Seldom used.
;00 = 146.580,100.0,m
;01 = 147.030,103.5,m+t
;02 = 147.240,103.5,m+t
;03 = 147.765,79.7,m-t
;04 = 146.460,100.0,m
;05 = 146.550,100.0,m
[macro]
;;;;; Macro commands ;;;;;
;1 = *812000
;2 = *822000
;3 = *832000
;4 = 3199832000
;[daq-list]
;;;;; Data Acquisition configuration ;;;;;
;Where: device_name1 and device_name2 are stanzas you define in this file
;device = daq-cham-1
;device = device_name1
;device = device_name2
;[daq-cham-1] ; Defined in [daq-list]
; Device name
;hwtype = uchameleon ; DAQ hardware type
;devnode = /dev/ttyUSB0 ; DAQ device node (if required)
;1 = inadc ; Pin definition for an ADC channel
;2 = inadc
;3 = inadc
;4 = inadc
;5 = inadc
;6 = inadc
;7 = inadc
;8 = inadc
;9 = inp ; Pin definition for an input with a weak pullup resistor
;10 = inp
;11 = inp
;12 = inp
;13 = in ; Pin definition for an input without a weak pullup resistor
;14 = out ; Pin definition for an output
;15 = out
;16 = out
;17 = out
;18 = out
;[meter-faces]
;face = scale(scalepre,scalediv,scalepost),word/?,...
; scalepre = offset to add before dividing with scalediv
; scalediv = full scale/number of whole units (e.g. 256/20 or 12.8 for 20 volts).
; scalepost = offset to add after dividing with scalediv
;face = range(X-Y:word,X2-Y2:word,...),word/?,...
;face = bit(low-word,high-word),word/?,...
; word/? is either a word in /var/lib/asterisk/sounds or one of its subdirectories,
; or a question mark which is a placeholder for the measured value.
; Battery voltage 0-20 volts
;batvolts = scale(0,12.8,0),rpt/thevoltageis,?,ha/volts
; 4 quadrant wind direction
;winddir = range(0-33:north,34-96:west,97-160:south,161-224:east,225-255:north),rpt/thewindis,?
; LM34 temperature sensor with 130 deg. F full scale
;lm34f = scale(0,1.969,0),rpt/thetemperatureis,?,degrees,fahrenheit
; Status poll (non alarmed)
;light = bit(ha/off,ha/on),ha/light,?
;[alarms]
;tag = device,pin,node,ignorefirst,func-low,func-hi
;tag = a unique name for the alarm
;device = daq device to poll
;pin = the device pin to be monitored
;ignorefirstalarm = set to 1 to throwaway first alarm event, or 0 to report it
;node = the node number to execute the function on
;func-low = the DTMF function to execute on a high to low transition
;func-high = the DTMF function to execute on a low to high transition
; a '-' as a function name is shorthand for no-operation
;door = daq-cham-1,9,1,2017,*7,-
;pwrfail = daq-cham-1,10,0,2017,*911111,-
;[events]
;;;;; Events Management ;;;;;
;status,2 = c|f|RPT_NUMLINKS ; Say time of day when all links disconnect.
[controlstates]
;;;;; Control states ;;;;;
; Allow several control operator functions to be changed at once using one command (good for scheduling)
;statenum = copcmd,[copcmd]... Rpt.conf - AllStarLink Wiki
0 = rptena,lnkena,apena,totena,ufena,noicd ; Normal operation
1 = rptena,lnkena,apdis,totdis,ufena,noice ; Net and news operation
2 = rptena,lnkdis,apdis,totena,ufdis,noice ; Repeater only operation
[schedule]
;;;;; Scheduler - execute a macro at a given time ;;;;;
;dtmf_function = m h dom mon dow ; ala cron, star is implied
;2 = 00 00 * * * ; at midnight, execute macro 2.
