Perhaps a better way to phrase my question would be:
When setting up the Radio Configuration for the node (on allstarlink.org), what is the node type? My choices are Repeater (full duplex), Simplex, Simplex with CT, or Remote Base.
My thought process would be that 'Repeater' would be used if the node was physically attached to the repeater (through the controller), Simplex would be used to allow local stations to access ASL via RF, and that Remote Base is used to link the node to a repeater via RF (which is what I'm doing).
Am I all wet?
And while I'm at it, what about Interface Type (usbradio, simpleusb, or beagle) and Interface Variety (URI or USB FOB, NHRC, or Dingotel). I'll be using one of Kevin Custers RA-42's.
Tnx,
Mike - WM4B
On Wed, May 16, 2018 at 1:44 PM, mwbesemer@cox.net wrote:
"links to the repeater only via the repeater input/output"... so no.
Mike
WM4B
On Wed, May 16, 2018 at 1:40 PM, Mike wrote:
Can you change the freq of operation of the radio attached by command 'within/though" this node # ?
...is the answer to your question. location does not matter.
...mike/kb8jnm
On 5/16/2018 12:54 PM, mwbesemer@cox.net wrote:
If a node is established at a location different from that of the repeater and links to the repeater only via the repeater input/output, would it be considered a non-frequency agile remote-base?
Mike
WM4B
Repeater:
Usually connected to a full duplex station. AllStarLink is the repeater controller.
Simplex with telemetry (CT):
Usually connected to a simplex station. Operates as a RF "hotspot"
Simplex without telemetry:
Usually connected to a existing repeater controller. Porvides AllStarLink access to the repeater.
Remote Base:
Usually a second radio connected to the AllStarLink node to provide node access to a radio at a superior location. May be frequency agile.
73, Steve N4IRS
Am I all wet?
Tnx,
Mike - WM4B
Mike
WM4B
...mike/kb8jnm
Mike
WM4B
