Node showing not registered
I was having issues with my simplex radio node. Long and short, the audio went dead over my alinco radio. Everything was conecting fine at the time. Tonight I have switched over to an Allscan
URI120. I have all the audio settings correct for the node and it sounds great. However, when I did the asl3 update, I can no longer connect to anyone. On the ASL "Portal" page, I can not access my server. it says error 04, bad request. Thank you for time, Todd W1TAL
Others will need to help you troubleshoot but in the meantime, your only node number shows not registered on the network.
I am hoping I found my own solution. I see the not registered as well, and when I ran it in April, it was fine. For some reason it totally kicked out my wifi info. Now it will not take the info in raspi-config.. at least if I run a lan line (annoying) I think it should work; even plugged into lan it wont register
Please run and post the output of asl-node-auth-check.
Checking configuration:
Info: rpt.conf has configuration for: 43124
Info: /etc/asterisk/iax.conf contains no registration lines.
Info: /etc/asterisk/rpt_http_registrations.conf contains 1 registration line(s)
Info: Registrations present for configured node(s): 43124
Info: IP from https://conntest-east1.allstarlink.org/ip reports: 184.60.136.50
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 184.60.136.50
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 184.60.136.50
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 184.60.136.50
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 184.60.136.50
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 184.60.136.50
OK: HTTP IP probes have consensus on the same perceived IP
OK: IAX IP probes have consensus on the same perceived IP
Testing node 43124:
OK: Node registration config is well-formed
OK: Node registration type is HTTP
OK: register.allstarlink.org is reachable (via HTTP)
Error: HTTP registration state is Not Registered
Info: Stopping node checks due to registration failure
Info: as further information will be unreliable
 Error: Node 43124 has 1 error(s)!
Please confirm that the node password at the AllStarLink portal (www.allstarlink.org, "Portal", "Node Settings") is an exact match to the one you saved on your server/node (sudo asl-menu, "Node Settings", "AllStar Node Setup Menu", "Update Node .....", "Node password").
It was not but I just changed it and restarted asterisk.. no change
Can you (again) check that the passwords EXACTLY match, reboot the server/node, and run the asl-node-auth-check command.
