Date: 2009/10/19 Mon PM 03:48:29 PDT
CC: app_rpt mailing list <app_rpt-users@qrvc.com>
Subject: [App_rpt-users] Node segfaulting help please
Hi all,
I was wondering where the scripts for updating, taking down and bringing up
App_rpt are hiding on the new install.
I built a new node recently ( well quite a few ) and I have two of them that
segfault when I try to run the "radio tune rxvoice" routine.
I was going to try and reinstall remotely - is there any way of running the
installation phase scripts remotely?
Thanks in advance for any help received,
Matt
G4RKY
phase1.sh and phase2.sh cannot be run remotely. They are only part of the install process. astupd.sh is the script
you want to run, but if your system(s) are not ACID version 0.9 then you'll have to re-install from scratch. The script will refuse to do an update if the versions don't match.
The helper scripts are located in:
/usr/local/sbin and that should be part of the path.
If it still segfaults after installing ACID 0.9, then you might want to compare configs against working and non-working nodes to see what usbradio setting(s) is causing the problem. There could be an unreported bug in chan_usbradio.c
Ah thank you for such a speedy response Steve, much appreciated. Got them now!
I found astinstall.sh and ran that ( on the basis it couldnt be any more broken than it was! ) and it has seemed to fix the problem. I will leave this node on test overnight and see how it goes.
All my nodes are Acid nodes built from the latest release - I can see you guys have been hard at work with some exciting developments in the pipeline, judging from my rpt.conf file!!
I need to use the rxondelay on this node, to stop this ping-pong problem, is it straightforward to use and where do I put it in rpt.conf?
Hi all,
segfault when I try to run the “radio tune rxvoice” routine.
Matt
G4RKY
you want to run, but if your system(s) are not ACID version 0.9 then you’ll have to re-install from scratch. The script will refuse to do an update if the versions don’t match.
now!
Thanks again,
Matt
Hi all,
up
that
the
Matt
G4RKY
chan_usbradio.c
