Hi all
Does anyone have Node Remote 2.0 for Android working with ASL3 and can share their manager.conf file settings?
Cheers
Colin, ZL2FL
Hi all
Cheers
Colin, ZL2FL
Perfect! Thank you so much ![]()
WHere you able to get this to work I have opened the port but still not able to get node remote to connect.
I have changed the manager.conf to match line for line what is on node remotes site not sure if that is wrong or what.
Did you restart asterisk after changeing the manager.conf file?
Yes restarted it. On the app it will switch screens and then go back to the input screen and say wrong info
For reference, I have an iPhone so YMMV.
To enable Node Remote I made 3 changes to my node :
[remote]
secret = 12345
read = all,system,call,log,verbose,command,agent,user,config
write = all,system,call,log,verbose,command,agent,user,config
Yes, step (#3) is optional.
Yes, you can use a stanza name other than âremoteâ. Just be consistent in where you use it.
Yes, you can use whatever âsecretâ you want. For me, I was going for something easy to remember/type.
Yes, one should be able to thin down the allowed permissions
Then, in the Node Remote app I entered the Node Number, the user name âremoteâ (to match the manager.conf stanza), the password â12345â (again, matching the stanza), and the Node IP Address.
Here is my manager.conf which works for the Android app so ymmv also;
; Asterisk Call Management support
; By default asterisk will listen on localhost only.
[general]
displaysystemname = yes
enabled = yes
webenabled = yes
port = 5038
bindaddr = 0.0.0.0 ; Comment when not localhost access
[admin]
secret = xxxxxxxx ;<---- your password!
;deny = 0.0.0.0/0.0.0.0 ; Uncomment when not localhost
permit=1.2.3.4/255.255.255.255 ; Uncomment when not localhost
Did you intentionally remove the semi-colon â;â from the âpermit=â line?
What happens if you turn that line back into a comment?
Yes as @WA3WCO was hinting to, this âonlyâ allows that IP for connection to the manager.
If it is correct, then all should be good.
If localhost âonlyâ 127.0.0.1 but a test to not use it is in order.
Also note that the cache on your browser may need cleared if you make changes.
Thanks followed this to the âTâ and it worked i think it has to do with the username being the stanza name and that isnt documented anywhere that I could find.
It was in one piece of documentation I found, but Iâve tested it again with that commented out and it works fine. So that is not required.
I have done all was needed, but the Allmon3 stops working and the log says that 127.0.01:5038 can not be reached.
I will add the screenshot when I get back from work.
This is the original Manager.conf
After the changes from ZL2FL
Allmon error
So clearly there is something wrong and the Author of Node remote was pretty no help and I paid like everyone!
If you changed the âsecretâ in â/etc/asterisk/manager.confâ then you need to :
Resolved⌠But all request to connect are connection failed.
How do I correct the âUnable to fetch astdb.txtâ error?
73,
Jeff K3JRZ
I have Node Remote installed on my iPhone. I have no idea what version it is because thereâs no way to display the version in the app. The Node Remote iPhone app works, but Iâm also getting the âUnable to fetch astdb.txtâ error. I watched a Ham Radio Crusader video about Node Remote, and the same âUnable to fetch astdb.txtâ error is shown in his YouTube video. He didnât mention anything about the error that was clearly displayed in the YouTube video. I asked Freddie Mac about the error, and there was no response. So, I donât have a clue about the âUnable to fetch astdb.txtâ error! But the Node Remote app still works despite the error!
A copy of astdb.txt is distributed by the asl3-update-nodelist package. That is installed by default on ASL3 Appliances but needs to be manually installed in other situations. If thatâs installed and working, then itâs most likely a Node Remote problem.
Iâm surprised that Freddie didnât reply back. Iâll have to ask him if he knows of this issue & how to fix.
I did find this info on the reviews for the app on the App Store:
ln -s /var/log/asterisk/astdb.txt /var/www/html/(your_dashbord_dir -allmon2/allmon3/supermon)/astdb.txt
NOTE: Replace â(your_dashbord_dir -allmon2/allmon3/supermon)â with the folder name of whatever dashboard that you are running. Iâm running Supermon 7.4+ so I would have âsupermonâ there.
Iâm no Linux expert so I havenât attempted to try this yet. the âlnâ (lima november) command will put a hard/symbolic (when using â-sâ) link between the two files. You can go to both folders and see the astdb.txt file in both.
