Node Registration Failure
Hi,
One of my nodes (2482) sits behind an ADSL connection with a
dynamic IP address (changes any time the router is re-started etc).
For a while, all was well, and it appeared on the status
pages on the website.
Following a few network upsets (i.e. renewed IP addresses)–
but no configuration changes – the node no longer appears in the list.
I modified the “statpost_program” line in
rpt.conf to direct output to a file, rather than /dev/null. The resulting file
contains this one-liner:
Error! Not Authorized from IP 80.65.243.181
The IP given is the correct public IP that my ADSL router
currently has assigned to it. As far as I can tell, the “register”
entry in iax.conf is correct – I certainly never changed it after it was
initially working.
Any Ideas??
David Osborn – GD4HOZ
