Node 2211 is still not showing up in the active nodes list. [http://stats.allstarlink.org/
](http://stats.allstarlink.org/)
It does, however, show up green in the System-wide nodes list, and Web transceiver. Inbound and outbound calls seem to
work 100%. Today I tried moving the node to another server and back. No change. I also wanted to try changing the password
on the portal for 2211, but couldn't find a way to do that.
Any more ideas? Thanks .73
Kyle
K0KN
<details class='elided'>
<summary title='Show trimmed content'>···</summary>
--- Original Message ---
Hello group,
An odd thing happened a few days ago.
One of my 6 nodes no longer appears on the Allstar active nodes list [http://stats.allstarlink.org/](http://stats.allstarlink.org/)
Nothing has changed on my end. I've made sure that the stanza for node status reporting is uncommented in rpt.conf.
This server is running 3 nodes, 2210-2212 and 2210,2212 show up. The node reporting stanzas are identical on all 3 nodes.
I can use 2211 as before, it will successfully connect to other stations, etc, but does not display correctly if connected to another station. For example, I connected 2211 to my node 2215. Node 2211 appears to be a non-standard node. See URL: [http://stats.allstarlink.org/nodeinfo.cgi?node=2215](http://stats.allstarlink.org/nodeinfo.cgi?node=2215)
Any ideas? I'm stumped.
Thanks. 73
Kyle
K0KN
