Node Not Reporting Stats
I have a node 620591 that is indicating it is not reporting stats or is offline. I tried the diagnostics and I can ping the allmon server. The node is running on a Pi3+. Any help?
Dave, WA6IFI
Dave, you didn't say if it was reporting and suddenly stopped or never worked at all.
Allmon has nothing to do with any of that.
Take a look in your rpt.conf file
; *** Status Reporting ***
; Uncomment the following "statpost_url" line to enable status reporting
; of all of your nodes to "stats.allstarlink.org".  To enable reporting
; of a single node then add the line (without the leading ";") to the
; per-node stanza(s).
;statpost_url = http://stats.allstarlink.org/uhandler ; Status updates
