I am pretty sure my new SHARI node is setup correctly, but my node is not registering.
When I run the check_reg.sh command it returns the following.
Where is 255.255.255.255 coming from, and sometimes is has REJECTED in that place.
[root@WA6JFK-54592 supermon]# check_reg.sh
Node - 54592 at IP address- 255.255.255.255, Port- 4569 is “Registered” at Server
IP- 162.248.92.131 (register-central.allstarlink.org.), Port- 4569
DNS lookup returns - +OK|radio@172.249.183.21:4569/54592,172.249.183.21
Node - 54592#4569 at IP address- 172.249.183.21, Port- 4569 is “Registered” at Server
IP- 74.91.126.182 (hvdallas2.hamvoip.xxx), Port- 4569
