I am working on a ASL-DMR Bridge in the Cloud, (Node 52417) It is currently running, I have been able to make a contact between a
DMR Handheld <> Pi-Zero Hot Spot <> Brandmeister TG <> CLOUD SERVER <> Private Node 1999 <> ASL Node 52417 <> ASL Node 29332
In Allstar Monitor II - I get Node not in database as shown below. I am assuming I missed an edit in some configuration file, but have no clue which as I have gone back thru everything twice with no result.
Server is Debian 9 (at Vultr.com), I have installed Allmon2, but do not have SUPERMON and cannot find a download or package manager to add it in. Is there a link or do I need to just copy the html/php files from a working Pi?
Oh, so this is an Allmon issue? if so you need to run astdb.php as mentioned in the README. For private nodes there is a text file to store whatever name you want to give it.
- Mark astdb.php executable and add to cron. Run just once a day please. ie
01 03 * * * cd /var/www/html/allmon2; ./astdb.php
Good morning, I have the beta version 2.0 AMD installed in VirtualBox, it gives me three errors. 1.- Menu does not change the repeater password, (that is not vital). 2.- Node not in database (exceeded after several hours of server operation), now it does not connect DVS apk. 3.- Manager allmon does not open with the defined password.
Be sure your statpost lines are not commented out in rpt.conf.
Allmon does not have a default password. It must be created for the directory by Apache.
See the allmon instructions once again. It can be easy to miss. https://wiki.allstarlink.org/wiki/Allmon2_Install
