Node not currently registered
I have node number 59258 on server 43885 with callsign KD5DFL
Under the "KD5DFL Nodes" is where this shows.
Under Currently Registered it says No.
This WAS registered. How do I get it registered again.
Scott Wren, KD5DFL
Please run asl-node-auth-check for troubleshooting. Post results here if you need more help.
root@node63237:/home/asl# asl-node-auth-check
-----===== AllStarLink Node Authentication Check =====-----
Checking configuration:
Info: rpt.conf has configuration for: 63237
Info: /etc/asterisk/iax.conf contains 1 registration line(s)
Error: Invalid registration >> [email protected] << in /etc/asterisk/rpt_http_registrations.conf
Info: /etc/asterisk/rpt_http_registrations.conf contains 1 registration line(s)
Info: Registrations present for configured node(s): 63237, 63237
Error: Duplicated HTTP and IAX registrations for: 63237
Error: Cannot continue; reconcile configuration before proceeding
im totally lost can you help
The registration line /etc/asterisk/rpt_http_registrations.conf should look like :
register => 1234:[email protected]
On your server/node :
  1. Edit the rpt_http_registrations.conf file on your server/node
    • sudo asl-menu
    • 6 Expert Configuration Menu
    • 2 Edit rpt_http_registrations.conf file
  2. Update the register => ... line so that it matches the above pattern
    • Replace the "1234" with your node number.
    • Replace the "abcdef" with the password for your node from the www.allstarlink.org Portal / Node Settings.
  3. Restart asterisk (or your server/node)
  4. Run asl-node-auth-check again
