Something odd with your route it seems… you can see my results below.
At least we know your DNS is working…
traceroute to 67.215.233.179 (67.215.233.179), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 0.379 ms 0.458 ms 0.579 ms
2 192.168.2.1 (192.168.2.1) 3.168 ms 3.208 ms 3.231 ms
3 bc1041.bendcable.com (66.220.104.1) 13.333 ms 15.273 ms 15.498 ms
4 60.157.100.208.bendbroadband.com (208.100.157.60) 15.756 ms 15.786 ms 15.924 ms
5 70.157.100.208.bendbroadband.com (208.100.157.70) 20.173 ms 20.257 ms 20.489 ms
6 208.100.157.0 (208.100.157.0) 27.521 ms 16.976 ms 19.051 ms
7 six.zayo.com (206.81.80.19) 22.664 ms 22.883 ms 22.548 ms
8 ae27.cs1.sea1.us.eth.zayo.com (64.125.29.0) 55.704 ms 55.915 ms 56.127 ms
9 ae3.cs1.sjc2.us.eth.zayo.com (64.125.29.42) 56.431 ms 60.333 ms 60.052 ms
10 ae0.cs2.sjc2.us.eth.zayo.com (64.125.28.141) 67.345 ms 67.765 ms 67.482 ms
11 ae2.cs2.lax112.us.eth.zayo.com (64.125.28.197) 65.084 ms 48.807 ms 53.387 ms
12 ae27.cr2.lax112.us.zip.zayo.com (64.125.30.187) 46.289 ms 49.735 ms 49.945 ms
13 ae10.er4.lax112.us.zip.zayo.com (64.125.21.114) 49.444 ms 45.777 ms 46.816 ms
14 64.124.85.222.IPYX-128160-956-ZYO.zip.zayo.com (64.124.85.222) 49.061 ms 49.881 ms 49.968 ms
15 colo-lax6.as8100.net (96.44.180.34) 50.081 ms 56.042 ms 55.644 ms
16 allstarlink.org (67.215.233.179) 56.172 ms 56.345 ms 59.065 ms
root@KC7DMF-1:/etc/asterisk/scripts/nws# ping 67.215.233.179
PING 67.215.233.179 (67.215.233.179) 56(84) bytes of data.
64 bytes from 67.215.233.179: icmp_seq=1 ttl=54 time=52.9 ms
64 bytes from 67.215.233.179: icmp_seq=2 ttl=54 time=55.0 ms
64 bytes from 67.215.233.179: icmp_seq=3 ttl=54 time=47.5 ms
64 bytes from 67.215.233.179: icmp_seq=4 ttl=54 time=42.7 ms
On Sun, May 29, 2016 at 10:08 PM, Jeremy Lincicome w0jrl1@gmail.com wrote:
Mark,
Here are the results of nslookup, ping, and traceroute.
nslookup [allstarlink.org](http://allstarlink.org)
Server: 127.0.1.1
Address: 127.0.1.1#53
Non-authoritative answer:
Address: 67.215.233.179
ping -c4 [67.215.233.179](http://67.215.233.179):
--- 67.215.233.179 ping statistics ---
4 packets transmitted, 0 received, 100% packet loss, time 3024ms
traceroute 67.215.233.179
packets
1 DD-WRT (192.168.55.1) 5.094 ms 22.644 ms 22.651 ms
2 [216-98-194-1.forethought.net](http://216-98-194-1.forethought.net) (216.98.194.1) 25.671 ms 31.059
ms 40.912 ms
3 [vl203.de01.forethought.net](http://vl203.de01.forethought.net) (206.124.21.201) 40.914 ms 40.908
ms 40.908 ms
4 [216-241-35-213.static.forethought.net](http://216-241-35-213.static.forethought.net) (216.241.35.213) 40.904
ms 40.897 ms 40.888 ms
5 [206-124-24-110.static.forethought.net](http://206-124-24-110.static.forethought.net) (206.124.24.110) 44.864
ms 44.866 ms 75.615 ms
6 [te4-1.cr01.lax.citylinkfiber.net](http://te4-1.cr01.lax.citylinkfiber.net) (216.243.117.17) 86.184 ms
58.349 ms 45.012 ms
7 [te4-1.cr01.sjc.citylinkfiber.net](http://te4-1.cr01.sjc.citylinkfiber.net) (216.243.119.129) 59.803 ms
59.797 ms 59.789 ms
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Jeremy W0JRL
On 05/29/2016 10:27 PM, Mark Johnston
wrote:
What does this give you?
nslookup allstarlink.org
and ping & traceroute
67.215.233.179
Mark
“Got Root?”
How many software engineers does it take to change a light bulb?
None. It’s a hardware problem.
Unix is user friendly. It’s just very particular about who it’s friends are.
WINDOWS: Will Install Needless Data On Whole System
MICROSOFT: Most Intelligent Customers Realize Our Software Only Fools Teenagers.
A ntennas
P oorly
P laced
L acks
E ngineering
The best way to accelerate a computer running Windows is at 9.81 m/s².
“I get paid to support Windows, I use Linux to get work done.”
“Got Root?”
How
bulb?
** None.
It’s a hardware problem.**
Unix
it’s friends are.
MICROSOFT: Most
Fools Teenagers.
A
ntennas
P oorly
P laced
L acks
E ngineering
at 9.81 m/s².
**** “I
get work done.”****
On Sun, May 29, 2016 at 9:21 PM, Jeremy
wrote:
Bryan,
I checked the rc.updatenodelist script and the url looks
fine. I also checked the router firewall settings, and the
router is set up correctly.
David,
I looked at iax.conf, and it seams to be set up correctly.
The register statement looks like:
register = 29997:123456@register.allstarlink.org
(not the real password)
Also, I performed the following steps:
1. asterisk -vvvr
2. iax2 show registry
The output that I get is:
Host dnsmgr Username Perceived Refresh
State
[67.215.233.178:4569](http://67.215.233.178:4569)
Y 29997 60 Timeout
I'm not able to browse to [allstarlink.org](http://allstarlink.org). However, [google.com](http://google.com), [duckduckgo.com](http://duckduckgo.com), and [stats.allstarlink.org](http://stats.allstarlink.org)
all work fine.
73,
Jeremy W0JRL
On 05/29/2016 07:45 PM, David McGough wrote:
Jeremy,
The issue is that node 29997 isn't properly registered
with
Asterisk---check the registration settings in you
iax.conf file or
firewall/network changes.
The nodelist servers return a 403 error when a
nodelist download request
is performed from unrecognized IP addresses---the
query IP address isn’t
allowed if the registration process fails.
73, David KB4FXC
On Sun, 29 May 2016, Bryan D. Boyle wrote:
http://www.checkupdown.com/status/E403.html
So, check that the url in your update script is
formatted properly or
there are no extraneous characters in the wget
statement that actually
grabs the file. 403 is the web server's response to
an http request that
is forbidden. IOW, you are asking for something which
the web server is
configured to not give you.
Entitely different than the registration process
that puts your node in the list.
Bryan
Sent from my iPhone 6S...No electrons were harmed in
the sending of this message.
On May 29, 2016, at 17:12, Jeremy Lincicome <w0jrl1@gmail.com >
wrote:
Hi list,
I'm wondering if there is an issue with node 29997
server side. The node will not download the node
list.
I thought that I may have caused the issue by
changing firewall settings on the router. However,
after factory resetting the router, the list will
still not download.
Watching the node on a traffic analyzer, it looks
like the node is receiving 403 errors from the
servers.
When I look at [stats.allstarlink.org](http://stats.allstarlink.org) ,
the node shows as being online.
None of the other nodes that I manage are having
this issue.
Any assistance with resolving this issue is
appreciated.
73,
W0JRL
To unsubscribe from this list please visit [](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)[http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
and scroll down to the bottom of the page. Enter
your email address and press the “Unsubscribe or
edit options button”
You do not need a password to unsubscribe, you can
do it via email confirmation. If you have trouble
unsubscribing, please send a message to the list
detailing the problem.
and scroll down to the bottom of the page. Enter your
email address and press the “Unsubscribe or edit
options button”
You do not need a password to unsubscribe, you can do
email address and press the “Unsubscribe or edit options
button”
You do not need a password to unsubscribe, you can do it
