Node Keeps Dropping
I can connect to a node like ECR and I can transmit and receive for a couple of minutes. Then the connection just drops. I can reconnect and a few minutes later it drops again. Any help with what I need to do to make the connections stay put would be greatly appreciated. Thanks.
I suspect you're behind a Carrier Grade NAT system. Please post the output of asl-node-auth-check.
Here is the result: Looks like it does not like the links.
-----===== AllStarLink Node Authentication Check =====-----
Checking configuration:
Info: rpt.conf has configuration for: 41595
Info: /etc/asterisk/iax.conf contains no registration lines.
Info: /etc/asterisk/rpt_http_registrations.conf contains 1 registration line(s)
Info: Registrations present for configured node(s): 41595
Info: IP from ttps://conntest-east1.allstarlink.org/ip reports: 69.64.113.133
Info: IP from ttps://conntest-west1.allstarlink.org/ip reports: 69.64.113.133
Info: IP from ttps://conntest-west2.allstarlink.org/ip reports: 69.64.113.133
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 69.64.113.133
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 69.64.113.133
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 69.64.113.133
OK: HTTP IP probes have consensus on the same perceived IP
OK: IAX IP probes have consensus on the same perceived IP
Testing node 41595:
OK: Node registration config is well-formed
OK: Node registration type is HTTP
OK: egister.allstarlink.org is reachable (via HTTP)
OK: HTTP registration state is Registered
OK: Perceived IAX IP:PORT for this node is: 69.64.113.133:4569
OK: Registered to ws-east1a-register1.allstarlink.org - 52.21.169.197
OK: Server-set UDP port matches bindport in iax.conf
OK: Node registration within 10 minutes: 2026-11-06 15:17:54 UTC
Info: Last time IP changed was 2026-11-05 17:02:55 UTC
Warning: Node is not perceived as registered; not tested
Warning: Node 41595 has 1 warning(s)!
Warning: Warnings may or may not be problems depending on configuration
Do you have UDP/4569 forwarded into your network to your node? It's awkwardly displayed right now, but that usually means the node checker cannot independently connect to UDP/4569.
Good point, I'm checking into that today. I do not control the internet connection. Will that cause the drops? No UDP/4569 port forwarding?
Depending on the type of firewall, yes. If your outgoing connection creates the UDP session but it closes after a timeout period then your connection fails. You connect again and it works again for that timeout period.
FYI you're not blocked on ECR.
I'm looking at your nodes "stats" reporting and it's looking like the server may not be staying up. Can you check to see if you have any core files in your /var/lib/asterisk directory? You can do this from the Terminal with the following command:
ls -l /var/lib/asterisk
You might also want to use the Asterisk CLI to monitor the server activity. From the Terminal, exec sudo asterisk -r -vvvv and then watch the output for about 10 minutes. With no activity you should not see much output. After watching for a bit you can exit the CLI with quit. Paste the output here if you see anything interesting or questionable.
root@n3hww220:/var/log/asterisk# ls -l /var/lib/asterisk
total 6605564
-rw-r--r-- 1 asterisk asterisk 12288 Oct 30 14:50 astdb.sqlite3
-rw-r--r-- 1 asterisk asterisk 1455761 Nov 6 05:29 astdb.txt
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:38 core.1000
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:26 core.10028
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:27 core.10080
-rw------- 1 asterisk asterisk 96600064 Oct 30 15:27 core.10133
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:27 core.10191
-rw------- 1 asterisk asterisk 96583680 Oct 30 15:27 core.10243
-rw------- 1 asterisk asterisk 96583680 Oct 30 15:27 core.10296
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:27 core.10349
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:30 core.1042
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:27 core.10423
-rw------- 1 asterisk asterisk 97091584 Oct 30 15:28 core.10482
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:28 core.10536
-rw------- 1 asterisk asterisk 96579584 Oct 30 15:28 core.10588
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:28 core.10640
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:28 core.10692
-rw------- 1 asterisk asterisk 96579584 Oct 30 15:28 core.10749
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:28 core.10807
-rw------- 1 asterisk asterisk 96571392 Oct 30 15:28 core.10861
-rw------- 1 asterisk asterisk 96600064 Oct 30 15:29 core.10934
-rw------- 1 asterisk asterisk 96604160 Oct 30 15:29 core.10986
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:29 core.11038
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:29 core.11090
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:29 core.11143
-rw------- 1 asterisk asterisk 96583680 Oct 30 15:30 core.1117
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:29 core.11195
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:29 core.11248
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:30 core.11324
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:30 core.11376
-rw------- 1 asterisk asterisk 96571392 Oct 30 15:38 core.1167
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:31 core.1169
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:38 core.1220
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:31 core.1226
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:38 core.1277
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:31 core.1278
-rw------- 1 asterisk asterisk 96542720 Oct 30 15:39 core.1329
-rw------- 1 asterisk asterisk 96583680 Oct 30 15:31 core.1330
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:39 core.1381
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:31 core.1382
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:39 core.1433
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:31 core.1434
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:39 core.1485
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:31 core.1521
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:39 core.1537
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:39 core.1605
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:32 core.1617
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:39 core.1657
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:32 core.1711
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:40 core.1741
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:32 core.1772
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:32 core.1825
-rw------- 1 asterisk asterisk 96555008 Oct 30 15:40 core.1850
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:32 core.1912
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:40 core.1932
-rw------- 1 asterisk asterisk 96583680 Oct 30 15:32 core.1968
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:40 core.1991
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:32 core.2020
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:40 core.2044
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:32 core.2072
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:40 core.2101
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:33 core.2124
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:40 core.2153
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:33 core.2177
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:40 core.2205
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:33 core.2233
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:41 core.2263
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:33 core.2296
-rw------- 1 asterisk asterisk 96555008 Oct 30 15:41 core.2326
-rw------- 1 asterisk asterisk 96571392 Oct 30 15:33 core.2371
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:41 core.2405
-rw------- 1 asterisk asterisk 96579584 Oct 30 15:33 core.2423
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:41 core.2457
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:41 core.2509
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:33 core.2527
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:41 core.2561
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:34 core.2579
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:41 core.2613
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:34 core.2631
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:42 core.2665
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:34 core.2684
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:42 core.2718
-rw------- 1 asterisk asterisk 96579584 Oct 30 15:34 core.2736
-rw------- 1 asterisk asterisk 96583680 Oct 30 15:34 core.2810
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:42 core.2843
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:34 core.2862
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:42 core.2895
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:34 core.2914
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:42 core.2947
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:35 core.2966
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:42 core.2999
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:35 core.3018
-rw------- 1 asterisk asterisk 96555008 Oct 30 15:42 core.3051
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:35 core.3070
-rw------- 1 asterisk asterisk 97079296 Oct 30 15:43 core.3103
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:35 core.3125
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:43 core.3160
-rw------- 1 asterisk asterisk 97103872 Oct 30 15:35 core.3199
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:43 core.3238
-rw------- 1 asterisk asterisk 96600064 Oct 30 15:35 core.3252
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:43 core.3291
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:35 core.3315
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:36 core.3373
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:43 core.3401
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:36 core.3425
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:43 core.3455
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:36 core.3477
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:43 core.3507
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:36 core.3531
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:43 core.3559
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:36 core.3583
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:44 core.3611
-rw------- 1 asterisk asterisk 96550912 Oct 30 15:36 core.3657
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:44 core.3663
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:36 core.3714
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:44 core.3737
-rw------- 1 asterisk asterisk 96575488 Oct 30 15:36 core.3767
-rw------- 1 asterisk asterisk 96555008 Oct 30 15:44 core.3789
-rw------- 1 asterisk asterisk 96571392 Oct 30 15:37 core.3819
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:44 core.3841
-rw------- 1 asterisk asterisk 96571392 Oct 30 15:37 core.3871
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:44 core.3893
-rw------- 1 asterisk asterisk 96571392 Oct 30 15:37 core.3924
-rw------- 1 asterisk asterisk 96559104 Oct 30 15:44 core.3951
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:37 core.3980
-rw------- 1 asterisk asterisk 96542720 Oct 30 15:45 core.4003
-rw------- 1 asterisk asterisk 96563200 Oct 30 15:37 core.4032
-rw------- 1 asterisk asterisk 96555008 Oct 30 15:45 core.4057
-rw------- 1 asterisk asterisk 96555008 Oct 30 15:37 core.4106
-rw------- 1 asterisk asterisk 96555008 Oct 30 15:45 core.4131
-rw------- 1 asterisk asterisk 96567296 Oct 30 15:37 core.4158
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:23 core.8707
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:23 core.8761
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:24 core.8814
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:24 core.8867
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:24 core.8919
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:24 core.8972
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:24 core.9024
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:24 core.9076
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:24 core.9152
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:25 core.9204
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:25 core.9256
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:25 core.9308
-rw------- 1 asterisk asterisk 96579584 Oct 30 15:25 core.9360
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:25 core.9412
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:25 core.9464
-rw------- 1 asterisk asterisk 96595968 Oct 30 15:25 core.9517
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:25 core.9590
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:26 core.9642
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:26 core.9694
-rw------- 1 asterisk asterisk 96587776 Oct 30 15:26 core.9746
-rw------- 1 asterisk asterisk 96583680 Oct 30 15:26 core.9846
-rw------- 1 asterisk asterisk 96591872 Oct 30 15:26 core.9899
-rw------- 1 asterisk asterisk 96571392 Oct 30 15:26 core.9951
drwxr-xr-x 2 asterisk asterisk 4096 May 28 14:43 moh
drwxr-xr-x 2 asterisk asterisk 4096 May 28 14:43 priv-callerintros
drwxr-xr-x 2 asterisk asterisk 4096 Oct 22 08:37 scripts
drwxr-xr-x 3 asterisk asterisk 4096 Jul 19 13:05 sounds
root@n3hww220:/var/log/asterisk# sudo asterisk -r -vvvv
Asterisk 22.10.1+asl3-3.10.8-1.deb13, Copyright (C) 1999 - 2025, Sangoma Technologies Corporation and others.
Created by Mark Spencer [email protected]
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
Connected to Asterisk 22.10.1+asl3-3.10.8-1.deb13 currently running on n3hww220 (pid = 23410)
-- Remote UNIX connection
-- Remote UNIX connection disconnected
-- Channel Announcer/RXPChan-00000003;2 left 'softmix' base-bridge <70403d88-fcc6-4320-9c94-2cbea910347d>
-- Channel Recorder/MonChan-00000002;2 left 'softmix' base-bridge <622f502c-8834-4af4-8986-9a6dfccf9cf5>
-- Channel Local/LocalTX@default-00000001;2 left 'softmix' base-bridge <622f502c-8834-4af4-8986-9a6dfccf9cf5>
-- Channel Announcer/TXPChan-00000004;2 left 'softmix' base-bridge <622f502c-8834-4af4-8986-9a6dfccf9cf5>
-- Channel Announcer/IAXLink-00000005;2 left 'softmix' base-bridge <70403d88-fcc6-4320-9c94-2cbea910347d>
-- Channel Recorder/PChan-00000000;2 left 'softmix' base-bridge <70403d88-fcc6-4320-9c94-2cbea910347d>
-- Hungup 'IAX2/12.17.28.195:4569-7626'
[2026-11-06 14:51:02.177] ERROR[23470]: manager.c:7068 process_message: Unable to process manager action 'RptStatus'. Asterisk is shutting down.
[2026-11-06 14:51:02.178] ERROR[23470]: manager.c:7068 process_message: Unable to process manager action 'COMMAND'. Asterisk is shutting down.
[2026-11-06 14:51:02.179] ERROR[23470]: manager.c:7068 process_message: Unable to process manager action 'RptStatus'. Asterisk is shutting down.
Asterisk cleanly ending (0).
Executing last minute cleanups
n3hww220*CLI>
Disconnected from Asterisk server
More complete capture:
Connected to Asterisk 22.10.1+asl3-3.10.8-1.deb13 currently running on n3hww220 (pid = 23647)
-- <Announcer/Telemetry-00000007;1> Playing 'digits/3.ulaw' (language 'en')
-- <Announcer/Telemetry-00000007;1> Playing 'digits/9.ulaw' (language 'en')
-- <Announcer/Telemetry-00000007;1> Playing 'rpt/connected-to.gsm' (language 'en')
-- <Announcer/Telemetry-00000007;1> Playing 'rpt/node.gsm' (language 'en')
-- <Announcer/Telemetry-00000007;1> Playing 'digits/4.ulaw' (language 'en')
-- <Announcer/Telemetry-00000007;1> Playing 'digits/1.ulaw' (language 'en')
-- <Announcer/Telemetry-00000007;1> Playing 'digits/5.ulaw' (language 'en')
-- Channel Announcer/Telemetry-00000007;2 left 'softmix' base-bridge
-- Channel Announcer/IAXLink-00000005;2 left 'softmix' base-bridge <78e09114-48b7-4059-908e-e1a1754f5e86>
-- Channel Recorder/PChan-00000000;2 left 'softmix' base-bridge <78e09114-48b7-4059-908e-e1a1754f5e86>
-- Channel Announcer/RXPChan-00000003;2 left 'softmix' base-bridge <78e09114-48b7-4059-908e-e1a1754f5e86>
[2026-11-06 15:01:20.419] WARNING[23777]: channel.c:764 __ast_channel_alloc_ap: Channel allocation failed: Refusing due to active shutdown
[2026-11-06 15:01:20.420] WARNING[23777]: core_unreal.c:1226 ast_unreal_new_channels: Unable to allocate owner channel structure
[2026-11-06 15:01:20.420] ERROR[23777]: app_rpt/rpt_bridging.c:298 __rpt_request_local_chan: Failed to request local channel
[2026-11-06 15:01:20.420] WARNING[23777]: app_rpt/rpt_telemetry.c:1596 rpt_tele_thread: Unable to obtain local channel (mode: 47)
-- Hungup 'IAX2/12.17.28.195:4569-8800'
[2026-11-06 15:01:21.346] ERROR[23717]: manager.c:7068 process_message: Unable to process manager action 'RptStatus'. Asterisk is shutting down.
[2026-11-06 15:01:21.347] ERROR[23717]: manager.c:7068 process_message: Unable to process manager action 'COMMAND'. Asterisk is shutting down.
[2026-11-06 15:01:21.348] ERROR[23717]: manager.c:7068 process_message: Unable to process manager action 'RptStatus'. Asterisk is shutting down.
n3hww220*CLI>
This explains why you've been having troubles. That's a LOT of core files.
This suggests something is off with an AMI interaction. Are you using Allmon3? Allscan? Supermon? ...?
Q? is the "339" the last digits of a longer node number that was trying to connect with your node? or is that a private node?
Q? can you tell us a bit more about this server/nodes configuration?
and, for the core files, we would need some additional info to see where/why the code is crashing.
# install debugging symbols
sudo apt update
sudo apt install asl3-asterisk-dbgsym asl3-asterisk-modules-dbgsym
# examine the most recent core file
sudo /var/lib/asterisk/scripts/ast_coredumper --latest
The last command should create a number of .txt files. Please "attach" the *-brief.txt file here ... and save a copy of the others (if needed, we'll ask for them later).
Sorry I have to put this on hold for a few days. Retirement party in 1 hour, coworker with my wife, tomorrow, haul a farm tractor 120 miles, Sunday, church then daughter is coming over. Monday drive to Maryland to pick up a truck. So hopefully Tuesday I can get back on this and I'll get the info requested. Have a good weekend.
