I have had this Shari node running for several years with no issues, however, a couple of weeks ago, it started to fail to connect to nodes I have been using regularly. I does not matter which node on Hubnet I choose it fails. The node address is sent out of internet, appears to connect for a couple of seconds and drops out. I have run the Asterisk CLI client and attach the result showing the failure. Any help to explain or cure this help greatly.
Malcolm M0MCR
Hi, and thanks for the link. My situation is not quite the same, my system does connect to any outbound address sent, even when sent from my handheld as an inbound command although the hand held is connected fine… I shall check some the points they make but my router hardware is different.
Cheers
Hi, I have 2 x Pi-Star nodes one running DMR and one Fusion also here and online, as they have all been for past 3 years without any issue. The Shari has also been running for the same time with them, with no issues.
So, it looks like you converted 52044 to NNX (so, your simplex node is now 520440). Was the change to NNX recent? If so, did this issue you are having start when you converted?
I have now, after reading the section on NNX from the link you sent to me, reset my node back to the original 52044 with no extensions, this appears to have solved the problem, other than I still cannot connect to the original node 41689. I must have some other issue somewhere that is stopping my node from connecting to 41689, as the node is up and running in the Hubnet bubble diagram.
When look at my node in the active node list, it says “Node configured incorrectly” or something similar. Any thoughts on what that might be, could it be related to my original issue??
