hi there i have 3 nodes 46174,29259,41412 i am about to set up another node so instead of applying for another node number i did an ext for node 41412,it gave me now 414120,an 414121 , my question these 2 new number is what i would used to set up an also i dont see 41412 anymore is that node still will be active.thanks tony.(NP2Q)
Your original node number (41412) is still yours and you can switch back to is any time. These wiki instructions show how to do that.
To have 414120 on the same server you must change 41412 to 414120. The Wiki shows you what and where to make changes.
Then you can add 414121 to your current or new server.
