Hi Folks,
I recently registered a new node number and then manually ran astdb.php on my second node when my new node’s details didn’t show up after a couple of days. The astdb.txt file in /var/log/asterisk was duly updated and I was then seeing all details on my second node.
I also have a third node (this time in the cloud) which also needs astdb.txt updating, but when I ran astdb.php it downloaded the txt file to the /user/local/sbin directory, next to the php file. Allstar wasn’t able to see it there (it was still showing just my new node’s number, not full details) so I moved astdb.txt to the /var/log/asterisk folder, as per my second node. Asterisk still shows only the new node’s number, not the extended details which I’ve confirmed in the txt file.
Does anyone know where I should put the txt file, and what the permissions need to be in order for asterisk to see it? I’m stumped …
