Node 668951 not being registered
Hello,
I’m having an issue with my AllStarLink node 668951 (IK5TWZ – Livorno).
The node is running and reachable locally, but it does not register
correctly and cannot link to any other AllStar node.
Any connection attempt goes to “connecting” and then disconnects.
Symptoms
iax2 show registry always shows:
Request Sent
Linking attempts (*3xxxxxx, *8xxxxxx) fail with connection failed
Node status page reports:
“Node is not reporting statistical data or is offline”
dig 668951.nodes.allstarlink.org returns no result
curl http://stats.allstarlink.org/uhandler returns Invalid Node
Environment
OS: Debian 12 (AllStarLink)
Asterisk: 22.5.2
ASL version: Allmon v3 1.7.0
IAX ports (4569 UDP) open, firewall disabled for testing
Public IP correctly set (externaddr)
rpt_http_registrations.conf configured and present
Local private node 1998 works correctly
Suspicions
I suspect an issue with node registration on the AllStar infrastructure
or a regression / incompatibility introduced in Allmon v3 1.7.0
or the node may have been automatically disabled after being offline
for a long time
Could you please check:
whether node 668951 is properly enabled on your side
if there are known issues with Allmon v3 1.7.0
or if any manual reactivation/reset is required.
Thank you very much for your support.
I’m adding a key technical detail regarding node 668951.
The node is correctly sending statpost updates to:
but the backend consistently replies with:
perform_statpost: Response: Unauthorized
This happens repeatedly and explains why:
  • the node never appears online,
  • no DNS record is published for 668951.nodes.allstarlink.org,
  • linking to other nodes is impossible.
The issue is therefore authorization/backend-related, not firewall, NAT, or local configuration.
Could you please verify the backend status of node 668951 and re-enable or reset its statpost authorization if needed?
Additional info: on the node, /var/lib/asterisk/asl3un-hash exists but is empty.
Statpost attempts return "Unauthorized".
This suggests the ASL3 trust token is missing and needs regeneration server-side.
sudo asl-show-version
OS Kernel : 6.12.47+rpt-rpi-v8
Asterisk : 22.5.2+asl3-3.6.3-1.deb12
ASL [app_rpt] : 3.6.3
Installed ASL packages :
Package Version
allmon3 1.7.0-1.deb12
asl3 3.12-1.deb12
asl3-asterisk 2:22.5.2+asl3-3.6.3-1.deb12
asl3-asterisk-config 2:22.5.2+asl3-3.6.3-1.deb12
asl3-asterisk-modules 2:22.5.2+asl3-3.6.3-1.deb12
asl3-menu 1.16-1.deb12
asl3-pi-appliance 1.10.1-1.deb12
asl3-update-nodelist 2.0.0-1.deb12
asl-apt-repos 2.0-1.deb12
cockpit 287.1-0+deb12u3
cockpit-ws 287.1-0+deb12u3
dahdi 1:3.1.0-2
dahdi-dkms 1:3.4.0-10.asl.deb12
dahdi-linux 1:3.4.0-10.asl.deb12
dahdi-source 1:3.4.0-10.asl.deb12
You are confusing the registration system with the stats gathering system. All of the stat-related items you mentioned - statpost errors, stats.allstarlink.org, etc. will ignore your node's data because it is not properly registered.
Are you using HTTP or IAX registration? What does rpt show registrations or iax2 show registry report based on your configuration? Have you reviewed your logging to at startup of Asterisk for what the error might be?
Usually, your problem is an incorrectly-configured node password set in asl-menu or you tried to hand-edit your configuration and broke something.
node668951CLI> rpt show registrations
No such command 'rpt show registrations' (type 'core show help rpt show registrations' for other possible commands)
node668951
CLI> iax2 show registry
52.20.63.146:4569 Y 668951 Unregistered 60 Timeout
1 IAX2 registrations.
sudo asterisk -rvvvvv
Asterisk 22.5.2+asl3-3.6.3-1.deb12, Copyright (C) 1999 - 2025, Sangoma Technologies Corporation and others.
Created by Mark Spencer markster@digium.com
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
Connected to Asterisk 22.5.2+asl3-3.6.3-1.deb12 currently running on node668951 (pid = 3021)
> Registered application 'CallCompletionCancel'
> ccss => (Call Completion Supplementary Services)
> Loading cdr.
[2026-01-12 21:01:32.088] NOTICE[3021]: cdr.c:4639 cdr_toggle_runtime_options: CDR simple logging enabled.
> cdr => (CDR Engine)
> Loading cel.
> cel => (CEL Engine)
> Loading dnsmgr.
[2026-01-12 21:01:32.095] NOTICE[3021]: dnsmgr.c:493 do_reload: Managed DNS entries will be refreshed every 300 seconds.
> dnsmgr => (DNS Manager)
> Loading dsp.
> dsp => (DSP)
> Loading enum.
> enum => (ENUM Support)
> Loading features.
> Registered custom function 'FEATURE'
> Registered custom function 'FEATUREMAP'
> Registered application 'Bridge'
> Manager registered action Bridge
> features => (Call Features)
> Loading http.
> http => (Built-in HTTP Server)
> Loading indications.
> Registered indication country 'at'
> Registered indication country 'au'
> Registered indication country 'bg'
> Registered indication country 'br'
> Registered indication country 'be'
> Registered indication country 'ch'
> Registered indication country 'cl'
> Registered indication country 'cn'
> Registered indication country 'cz'
> Registered indication country 'de'
> Registered indication country 'dk'
> Registered indication country 'ee'
> Registered indication country 'es'
> Registered indication country 'fi'
> Registered indication country 'fr'
> Registered indication country 'gr'
> Registered indication country 'hu'
> Registered indication country 'id'
> Registered indication country 'il'
> Registered indication country 'in'
> Registered indication country 'it'
> Registered indication country 'lt'
> Registered indication country 'jp'
> Registered indication country 'mx'
> Registered indication country 'my'
> Registered indication country 'nl'
> Registered indication country 'no'
> Registered indication country 'nz'
> Registered indication country 'ph'
> Registered indication country 'pl'
> Registered indication country 'pt'
> Registered indication country 'ru'
> Registered indication country 'se'
> Registered indication country 'sg'
> Registered indication country 'th'
> Registered indication country 'uk'
> Registered indication country 'us'
> Registered indication country 'us-old'
> Registered indication country 'tw'
> Registered indication country 've'
> Registered indication country 'za'
[2026-01-12 21:01:32.154] NOTICE[3021]: indications.c:1100 load_indications: Default country for indication tones: us
[2026-01-12 21:01:32.154] NOTICE[3021]: indications.c:424 ast_set_indication_country: Setting default indication country to 'us'
> indications => (Indication Tone Handling)
> Loading acl.
> acl => (Named ACL system)
> Loading manager.
> Manager registered action Ping
> Manager registered action Events
> Manager registered action Logoff
> Manager registered action Login
> Manager registered action Challenge
> Manager registered action Hangup
> Manager registered action Status
> Manager registered action Setvar
> Manager registered action Getvar
> Manager registered action GetConfig
> Manager registered action GetConfigJSON
> Manager registered action UpdateConfig
> Manager registered action CreateConfig
> Manager registered action ListCategories
> Manager registered action Redirect
> Manager registered action Atxfer
> Manager registered action CancelAtxfer
> Manager registered action Originate
> Manager registered action Command
> Manager registered action ExtensionState
> Manager registered action PresenceState
> Manager registered action AbsoluteTimeout
> Manager registered action MailboxStatus
> Manager registered action MailboxCount
> Manager registered action ListCommands
> Manager registered action SendText
> Manager registered action UserEvent
> Manager registered action WaitEvent
> Manager registered action CoreSettings
> Manager registered action CoreStatus
> Manager registered action Reload
> Manager registered action LoggerRotate
> Manager registered action CoreShowChannels
> Manager registered action CoreShowChannelMap
> Manager registered action ModuleLoad
> Manager registered action ModuleCheck
> Manager registered action AOCMessage
> Manager registered action Filter
> Manager registered action BlindTransfer
> Registered custom function 'AMI_CLIENT'
> Manager registered action BridgeList
> Manager registered action BridgeInfo
> Manager registered action BridgeDestroy
> Manager registered action BridgeKick
> manager => (Asterisk Manager Interface)
> Loading plc.
> plc => (PLC)
> Loading udptl.
> udptl => (UDPTL)
> Loading res_timing_dahdi.so.
> res_timing_dahdi.so => (DAHDI Timing Interface)
> Loading res_timing_timerfd.so.
> res_timing_timerfd.so => (Timerfd Timing Interface)
> Loading res_usbradio.so.
> res_usbradio.so => (USB Radio Resource)
> Loading res_crypto.so.
-- Loaded PUBLIC key 'allstar'
> res_crypto.so => (Cryptographic Digital Signatures)
> Loading chan_dahdi.so.
> Registered bridge technology native_dahdi
> Registered application 'DAHDISendKeypadFacility'
> Registered application 'DAHDISendCallreroutingFacility'
[2026-01-12 21:01:32.475] WARNING[3021]: chan_dahdi.c:18806 process_dahdi: Only FXO signalled channels may belong to a call group
[2026-01-12 21:01:32.475] WARNING[3021]: chan_dahdi.c:18814 process_dahdi: Only FXO signalled channels may belong to a pickup group
-- Automatically generated pseudo channel
> Registered channel type 'DAHDI' (DAHDI Telephony w/PRI & SS7 & MFC/R2)
> Registered application 'DAHDIAcceptR2Call'
> Registered custom function 'POLARITY'
> Manager registered action DAHDITransfer
> Manager registered action DAHDIHangup
> Manager registered action DAHDIDialOffhook
> Manager registered action DAHDIDNDon
> Manager registered action DAHDIDNDoff
> Manager registered action DAHDIShowChannels
> Manager registered action DAHDIShowStatus
> Manager registered action DAHDIRestart
> Manager registered action PRIShowSpans
> Manager registered action PRIDebugSet
> Manager registered action PRIDebugFileSet
> Manager registered action PRIDebugFileUnset
> chan_dahdi.so => (DAHDI Telephony w/PRI & SS7 & MFC/R2)
> Loading chan_iax2.so.
== Using IAX2 TOS bits 30
== Binding IAX2 to default address 0.0.0.0:4569
> Registered application 'IAX2Provision'
> Registered custom function 'IAXPEER'
> Registered custom function 'IAXVAR'
> Manager registered action IAXpeers
> Manager registered action IAXpeerlist
> Manager registered action IAXnetstats
> Manager registered action IAXregistry
> Registered channel type 'IAX2' (Inter Asterisk eXchange Driver (Ver 2))
== 10 helper threads started
== IAX Ready and Listening
-- Loaded provisioning template 'default'
> chan_iax2.so => (Inter Asterisk eXchange (Ver 2))
> Loading format_g723.so.
> Registered file format g723sf, extension(s) g723|g723sf
> format_g723.so => (G.723.1 Simple Timestamp File Format)
> Loading format_g726.so.
> Registered file format g726-40, extension(s) g726-40
> Registered file format g726-32, extension(s) g726-32
> Registered file format g726-24, extension(s) g726-24
> Registered file format g726-16, extension(s) g726-16
> format_g726.so => (Raw G.726 (16/24/32/40kbps) data)
> Loading format_gsm.so.
> Registered file format gsm, extension(s) gsm
> format_gsm.so => (Raw GSM data)
> Loading format_h263.so.
> Registered file format h263, extension(s) h263
> format_h263.so => (Raw H.263 data)
> Loading format_h264.so.
> Registered file format h264, extension(s) h264
> format_h264.so => (Raw H.264 data)
> Loading format_ilbc.so.
> Registered file format iLBC, extension(s) ilbc
> format_ilbc.so => (Raw iLBC data)
> Loading format_pcm.so.
> Registered file format pcm, extension(s) pcm|ulaw|ul|mu|ulw
> Registered file format alaw, extension(s) alaw|al|alw
> Registered file format au, extension(s) au
> Registered file format g722, extension(s) g722
> format_pcm.so => (Raw/Sun uLaw/ALaw 8KHz (PCM,PCMA,AU), G.722 16Khz)
> Loading format_sln.so.
> Registered file format sln, extension(s) sln|slin|raw
> Registered file format sln12, extension(s) sln12
> Registered file format sln16, extension(s) sln16
> Registered file format sln24, extension(s) sln24
> Registered file format sln32, extension(s) sln32
> Registered file format sln44, extension(s) sln44
> Registered file format sln48, extension(s) sln48
> Registered file format sln96, extension(s) sln96
> Registered file format sln192, extension(s) sln192
> format_sln.so => (Raw Signed Linear Audio support (SLN) 8khz-192khz)
> Loading format_vox.so.
> Registered file format vox, extension(s) vox
> format_vox.so => (Dialogic VOX (ADPCM) File Format)
> Loading format_wav_gsm.so.
> Registered file format wav49, extension(s) WAV|wav49
> format_wav_gsm.so => (Microsoft WAV format (Proprietary GSM))
> Loading format_wav.so.
> Registered file format wav, extension(s) wav
> Registered file format wav16, extension(s) wav16
> format_wav.so => (Microsoft WAV/WAV16 format (8kHz/16kHz Signed Linear))
> Loading sounds.
> sounds => (Sounds Index)
> Loading app_authenticate.so.
> Registered application 'Authenticate'
> app_authenticate.so => (Authentication Application)
> Loading app_dial.so.
> Registered application 'Dial'
> Registered application 'RetryDial'
> app_dial.so => (Dialing Application)
> Loading app_exec.so.
> Registered application 'Exec'
> Registered application 'TryExec'
> Registered application 'ExecIf'
> app_exec.so => (Executes dialplan applications)
> Loading app_playback.so.
> Registered application 'Playback'
> app_playback.so => (Sound File Playback Application)
> Loading app_rpt.so.
> Manager registered action RptLocalNodes
> Manager registered action RptStatus
> Registered application 'Rpt'
> Registered custom function 'RPT_TELEM_TIME'
> Registered application 'MDC1200Gen'
> app_rpt.so => (Radio Repeater/Remote Base Application)
> Loading app_sendtext.so.
> Registered application 'SendText'
> Registered application 'ReceiveText'
> app_sendtext.so => (Send and Receive Text Applications)
> Loading app_system.so.
> Registered application 'TrySystem'
> Registered application 'System'
> app_system.so => (Generic System() application)
> Loading app_transfer.so.
> Registered application 'Transfer'
> app_transfer.so => (Transfers a caller to another extension)
> Loading chan_echolink.so.
> Total of 1 Echolink instances found.
> Registered channel type 'echolink' (Echolink channel driver)
> chan_echolink.so => (Echolink Channel Driver)
> Loading chan_usrp.so.
> Registered channel type 'usrp' (USRP Driver)
> chan_usrp.so => (USRP Channel Module)
> Loading codec_adpcm.so.
> Registered translator 'adpcmtolin' from codec adpcm to slin, table cost, 900000, computational cost 612
> Registered translator 'lintoadpcm' from codec slin to adpcm, table cost, 600000, computational cost 469
> codec_adpcm.so => (Adaptive Differential PCM Coder/Decoder)
> Loading codec_alaw.so.
> Registered translator 'alawtolin' from codec alaw to slin, table cost, 900000, computational cost 231
> Registered translator 'lintoalaw' from codec slin to alaw, table cost, 600000, computational cost 213
> codec_alaw.so => (A-law Coder/Decoder)
> Loading codec_a_mu.so.
> Registered translator 'alawtoulaw' from codec alaw to ulaw, table cost, 915000, computational cost 352
> Registered translator 'ulawtoalaw' from codec ulaw to alaw, table cost, 915000, computational cost 254
> codec_a_mu.so => (A-law and Mulaw direct Coder/Decoder)
> Loading codec_g726.so.
> Registered translator 'g726tolin' from codec g726 to slin, table cost, 900000, computational cost 2253
> Registered translator 'lintog726' from codec slin to g726, table cost, 600000, computational cost 6001
> Registered translator 'g726aal2tolin' from codec g726aal2 to slin, table cost, 900000, computational cost 2297
> Registered translator 'lintog726aal2' from codec slin to g726aal2, table cost, 600000, computational cost 5969
> codec_g726.so => (ITU G.726-32kbps G726 Transcoder)
> Loading codec_gsm.so.
> Registered translator 'gsmtolin' from codec gsm to slin, table cost, 900000, computational cost 2233
> Registered translator 'lintogsm' from codec slin to gsm, table cost, 600000, computational cost 4626
> codec_gsm.so => (GSM Coder/Decoder)
> Loading codec_ulaw.so.
> Registered translator 'ulawtolin' from codec ulaw to slin, table cost, 900000, computational cost 355
> Registered translator 'lintoulaw' from codec slin to ulaw, table cost, 600000, computational cost 203
> codec_ulaw.so => (mu-Law Coder/Decoder)
> Loading format_mp3.so.
> Registered file format mp3, extension(s) mp3
> format_mp3.so => (MP3 format [Any rate but 8000hz mono is optimal])
> Loading func_base64.so.
> Registered custom function 'BASE64_ENCODE'
> Registered custom function 'BASE64_DECODE'
> func_base64.so => (base64 encode/decode dialplan functions)
> Loading func_callerid.so.
> Registered custom function 'CALLERID'
> Registered custom function 'CONNECTEDLINE'
> Registered custom function 'REDIRECTING'
> func_callerid.so => (Party ID related dialplan functions (Caller-ID, Connected-line, Redirecting))
> Loading func_cdr.so.
> Registered custom function 'CDR'
> Registered custom function 'CDR_PROP'
> func_cdr.so => (Call Detail Record (CDR) dialplan functions)
> Loading func_channel.so.
> Registered custom function 'CHANNEL'
> Registered custom function 'CHANNELS'
> Registered custom function 'CHANNEL_EXISTS'
> Registered custom function 'MASTER_CHANNEL'
> func_channel.so => (Channel information dialplan functions)
> Loading func_cut.so.
> Registered custom function 'CUT'
> Registered custom function 'SORT'
> func_cut.so => (Cut out information from a string)
> Loading func_db.so.
> Registered custom function 'DB'
> Registered custom function 'DB_EXISTS'
> Registered custom function 'DB_DELETE'
> Registered custom function 'DB_KEYS'
> Registered custom function 'DB_KEYCOUNT'
> func_db.so => (Database (astdb) related dialplan functions)
> Loading func_enum.so.
> Registered custom function 'ENUMRESULT'
> Registered custom function 'ENUMQUERY'
> Registered custom function 'ENUMLOOKUP'
> Registered custom function 'TXTCIDNAME'
> func_enum.so => (ENUM related dialplan functions)
> Loading func_env.so.
> Registered custom function 'ENV'
> Registered custom function 'STAT'
> Registered custom function 'FILE'
> Registered custom function 'FILE_COUNT_LINE'
> Registered custom function 'FILE_FORMAT'
> Registered custom function 'DIRNAME'
> Registered custom function 'BASENAME'
> func_env.so => (Environment/filesystem dialplan functions)
> Loading func_global.so.
> Registered custom function 'GLOBAL'
> Registered custom function 'GLOBAL_DELETE'
> Registered custom function 'GLOBAL_EXISTS'
> Registered custom function 'SHARED'
> func_global.so => (Variable dialplan functions)
> Loading func_groupcount.so.
> Received OK from Echolink server nasouth.echolink.org.
> Registered custom function 'GROUP_COUNT'
> Registered custom function 'GROUP_MATCH_COUNT'
> Registered custom function 'GROUP_LIST'
> Registered custom function 'GROUP'
> func_groupcount.so => (Channel group dialplan functions)
> Loading func_logic.so.
> Registered custom function 'ISNULL'
> Registered custom function 'SET'
> Registered custom function 'EXISTS'
> Registered custom function 'IF'
> Registered custom function 'IFTIME'
> Registered custom function 'IMPORT'
> Registered custom function 'DELETE'
> Registered custom function 'VARIABLE_EXISTS'
> func_logic.so => (Logical dialplan functions)
> Loading func_math.so.
> Registered custom function 'MATH'
> Registered custom function 'INC'
> Registered custom function 'DEC'
> Registered custom function 'MIN'
> Registered custom function 'MAX'
> Registered custom function 'ABS'
> func_math.so => (Mathematical dialplan function)
> Loading func_md5.so.
> Registered custom function 'MD5'
> func_md5.so => (MD5 digest dialplan functions)
> Loading func_rand.so.
> Registered custom function 'RAND'
> func_rand.so => (Random number dialplan function)
> Loading func_realtime.so.
> Registered custom function 'REALTIME'
> Registered custom function 'REALTIME_STORE'
> Registered custom function 'REALTIME_DESTROY'
> Registered custom function 'REALTIME_FIELD'
> Registered custom function 'REALTIME_HASH'
> func_realtime.so => (Read/Write/Store/Destroy values from a RealTime repository)
> Loading func_strings.so.
> Registered custom function 'FIELDQTY'
> Registered custom function 'FIELDNUM'
> Registered custom function 'FILTER'
> Registered custom function 'REPLACE'
> Registered custom function 'STRREPLACE'
> Registered custom function 'STRBETWEEN'
> Registered custom function 'LISTFILTER'
> Registered custom function 'REGEX'
> Registered custom function 'ARRAY'
> Registered custom function 'QUOTE'
> Registered custom function 'CSV_QUOTE'
> Registered custom function 'LEN'
> Registered custom function 'STRFTIME'
> Registered custom function 'STRPTIME'
> Registered custom function 'EVAL'
> Registered custom function 'KEYPADHASH'
> Registered custom function 'HASHKEYS'
> Registered custom function 'HASH'
> Registered application 'ClearHash'
> Registered custom function 'TOUPPER'
> Registered custom function 'TOLOWER'
> Registered custom function 'SHIFT'
> Registered custom function 'POP'
> Registered custom function 'PUSH'
> Registered custom function 'UNSHIFT'
> Registered custom function 'PASSTHRU'
> Registered custom function 'TRIM'
> Registered custom function 'LTRIM'
> Registered custom function 'RTRIM'
> func_strings.so => (String handling dialplan functions)
> Loading pbx_config.so.
== Setting global variable 'HOMENPA' to '999'
== Setting global variable 'NODE' to '668951'
== Setting global variable 'NODE1' to '1998'
> Time to scan old dialplan and merge leftovers back into the new: 0.000004 sec
> Time to restore hints and swap in new dialplan: 0.000024 sec
> Time to delete the old dialplan: 0.000001 sec
> Total time merge_contexts_delete: 0.000029 sec
> pbx_config successfully loaded 0 contexts (enable debug for details).
> Manager registered action DialplanExtensionAdd
> Manager registered action DialplanExtensionRemove
> pbx_config.so => (Text Extension Configuration)
> Loading chan_simpleusb.so.
> Registered channel type 'SimpleUSB' (Simple USB (CM108) Radio Channel Driver)
> chan_simpleusb.so => (SimpleUSB Radio Interface Channel Driver)
Asterisk Ready.
[2026-01-12 21:01:33.602] NOTICE[3071]: app_rpt.c:5546 load_config: Domain used for DNS node lookup is: nodes.allstarlink.org
-- Loading initial config for repeater 668951
[2026-01-12 21:01:33.605] NOTICE[3071]: app_rpt.c:5702 rpt_master: Normal Repeater Init 668951
-- Loading initial config for repeater 1998
[2026-01-12 21:01:33.609] NOTICE[3071]: app_rpt.c:5702 rpt_master: Normal Repeater Init 1998
[2026-01-12 21:01:33.857] WARNING[3077]: app_rpt.c:1043 perform_statpost: statpost to URL 'http://stats.allstarlink.org/uhandler?node=668951&time=1768248093&seqno=1&nodes=&apprptvers=3.6.3&apprptuptime=0&totalkerchunks=0&totalkeyups=0&totaltxtime=0&timeouts=0&totalexecdcommands=0&keyed=0&keytime=10' failed with code 401 : Unauthorized
> Directory completed downloading(full,compressed), 6588 records.
-- Accepting UNAUTHENTICATED call from 127.0.0.1:4569:
-- > requested format = ulaw,
-- > requested prefs = (ulaw|adpcm|gsm),
-- > actual format = ulaw,
-- > host prefs = (ulaw|adpcm|gsm),
-- > priority = mine
-- Call accepted by 127.0.0.1:4569 (format ulaw)
-- Format for call is (ulaw)
-- Executing [1998@radio-secure:1] Rpt("IAX2/127.0.0.1:4569-11699", "1998") in new stack
== Spawn extension (radio-secure, 1998, 1) exited non-zero on 'Surrogate/IAX2/127.0.0.1:4569-11699'
-- Hungup 'DAHDI/pseudo-1525910749'
-- <DAHDI/pseudo-21344321> Playing 'rpt/node.gsm' (language 'en')
-- <DAHDI/pseudo-21344321> Playing 'digits/1.ulaw' (language 'en')
> Received OK from Echolink server naeast.echolink.org.
> Directory completed downloading(partial,compressed), 299 records.
-- <DAHDI/pseudo-21344321> Playing 'digits/9.ulaw' (language 'en')
-- <DAHDI/pseudo-21344321> Playing 'digits/8.ulaw' (language 'en')
-- <DAHDI/pseudo-21344321> Playing 'rpt/connected-to.gsm' (language 'en')
-- <DAHDI/pseudo-21344321> Playing 'digits/6.ulaw' (language 'en')
-- <DAHDI/pseudo-21344321> Playing 'digits/5.ulaw' (language 'en')
-- Hungup 'DAHDI/pseudo-21344321'
-- Hungup 'DAHDI/pseudo-1626599108'
The node performs statpost immediately after startup, but the server always replies with HTTP 401 Unauthorized (confirmed with full Asterisk debug at startup).
This indicates the node is recognized but rejected server-side.
Please re-enable or reset node 668951 in the backend.
This proves several things:
  1. You have disabled HTTP registration in favor of IAX registration. There is generally no reason to do this and implies a hand-edited configuration.
  2. Your IAX registration is timing out. That means your node is not able to communication to the registration system on UDP/4569.
  3. Your diagnosis that the "node is recodnized but rejected server-side" is incorrect.The stats system will ALWAYS return Unauthorized until the node is properly registered. Stats collection is not fundamental to operations and connections.
This is a client-side problem with registration. I would suggest checking the register line in /etc/asterisk/iax.conf for the correct password and other attributes.
You’re right, I checked again and the issue was in iax.conf
Thank you.
