Hi all I have no 63587. Cannot seem to get it to get registered gone through everything a few times I’m obviously missing something I can connect to 55553 echo no problem works great. Any other nodes will not let me connect plus not showing registered on my page, can anybody please point me in the right direction thank you
The very first step would be to verify that usr/pass are correct for registration in iax.conf and the line(s) are not commented out.
Perhaps at the same time to verify net connectivity.
I have seen many dns and other networking issues so sometimes a reboot of router (1st) and server (2nd) are in order before you start pulling hair out.
Radiotech,
Make sure that the iax port you have designated for use on your local node, I believe in iax.conf, matches with what you have on the allstar website.
portal>server settings>click on your node and you will see the iax port number that the system is currently using
