My radioless ASL on dell 3040 works well except I noticed using node 55553 doesn’t give any respond as it should during audio tests. I can only hear a beep tone but no audio respond from the server. This is a fresh install with a small recommendations from David/NR9V (see photo) which I followed.
Is there anything else I should look for to make it worked?
Reading on the fly, apologizing for my English
Duplex = 3 ??! Duplex = 1 single node Duplex = 2 repeater
The Duplex = 3 setting in RPT.conf prevents the audio of the RX repeater is sent to the TX repeater. However, the courtesy tones, the terminal code, the voice messages and the audio of the connection are however sent to the repeater. PTT. Let me know if this was your problem
Thanks iu0ndt for the reply.
I have tried the rpt settings to 1 but didnt solved the issue. And besides, In my hamvoiip setup I am using duplex 3 as well in a radioless and node 55553 is working fine.
