HELP FOR WIFI!
Asterisk Version: 22.7.0+asl3-3.7.1-1.deb13
ASL3 Version: 3.15-1.deb13
Hi folks, Dave, total newbie here. I have allmon3, supermon and allscan and remote node (on my iPhone) working great via ethernet on my SHARI node. I just did all the software updates from Cockpit.
I am failing to find and connect to a WiFi network when I do a scan from Cockpit/terminal.
My end goal is to have my iPhone or Android phone as the hotspot to travel mobile with my hotspot. Right now, I just want my home wireless to work. It doesn’t.
I did not configure WiFi when I first built the image, I just used (and use) the ethernet port for my initial configuration and continued use.
I have a phone hotspot and my home wifi network configured via the Wifi manager in Cockpit as well. I can add and delete them at will too. Cockpit sees 2 mac addresses from the RPi, 88:xx:xx:xx:xx:c7 (eth0) and 88:xx:xx:xx:xx:c9 (wlan0). I cannot connect when I reboot and remove the ethernet.
I tried “rfkill list” and “rfkill unblock wifi”. The 2nd command released the soft (and hard) block on the wlan0 to NO. I am grasping at straws though and am just about done with the 3 remaining strands of hair on my head.
Clueless Dave, K6WDE
