(no subject)
I am haveing trouble setting up a remote base using a TM-271A. I have the folloing settings in my rpt.conf
[2555] ; Node id of Remote Base
rxchannel = Radio/usb1 ; Rx audio/signalling channel
functions = functions-remote
phone_functions=functions-remote
remote=tm271
ioport = /dev/ttyS0 ; Specify port for serial port (optional)
memory = memory ; Section to hold memory entries (optional)
authlevel = 0 ; Anyone can use it
duplex=0
statpost_program=/usr/bin/wget,-q,--output-document=/dev/null ; Program and options to send stats
statpost_url=http://stats.allstarlink.org/uhandler.php ; URL for status updates
When I connect I get serial errors, am I missing something?
[Sep 22 16:54:32] NOTICE[10614]: chan_echolink.c:2102 do_el_directory: Directory pgm done downloading(partial,compressed), 132 records
    -- Accepting AUTHENTICATED call from 172.31.1.164:
       > requested format = ulaw,
       > requested prefs = (ulaw),
       > actual format = ulaw,
       > host prefs = (ulaw|gsm),
       > priority = mine
    -- Executing [2555@radio-phone:1] Answer("IAX2/pbx-5488", "") in new stack
    -- Executing [2555@radio-phone:2] Wait("IAX2/pbx-5488", "2") in new stack
    -- Executing [2555@radio-phone:3] Rpt("IAX2/pbx-5488", "2555|P") in new stack
    -- Re-Loading config for repeater 2555
  == Parsing '/etc/asterisk/rpt.conf': Found
    -- rpt (Rx) initiating call to Radio/usb1 on Radio/usb1
  == Set device 5-1 to usb1
  == Parsing '/etc/asterisk/usbradio_tune_usb1.conf': Found
[Sep 22 16:54:36] WARNING[10860]: chan_usbradio.c:1436 hidthread: Loaded parameters from usbradio_tune_usb1.conf for device usb1 .
[Sep 22 16:54:36] NOTICE[10859]: app_rpt.c:4040 openserial: Opened serial port /dev/ttyS0
[Sep 22 16:54:36] NOTICE[10859]: app_rpt.c:8284 rpt_telemetry: Tracepoint rpt_telemetry() entered mode=38
[Sep 22 16:54:36] NOTICE[10859]: app_rpt.c:8478 rpt_telemetry: Tracepoint rpt_telemetry() exit
[Sep 22 16:54:36] NOTICE[10871]: app_rpt.c:4230 send_usb_txt: send_usb_txt SETFREQ 0.0 0.0 0.0 0.0 L
[Sep 22 16:54:36] NOTICE[10871]: app_rpt.c:11117 serial_remote_io: ioport=/dev/ttyS0 baud=13 iofd=0x4b
[Sep 22 16:54:37] WARNING[10871]: app_rpt.c:11140 serial_remote_io: Serial device not responding on node 2555
[Sep 22 16:54:37] NOTICE[10871]: app_rpt.c:11117 serial_remote_io: ioport=/dev/ttyS0 baud=13 iofd=0x4b
[Sep 22 16:54:38] WARNING[10871]: app_rpt.c:11140 serial_remote_io: Serial device not responding on node 2555
[Sep 22 16:54:38] NOTICE[10871]: app_rpt.c:11117 serial_remote_io: ioport=/dev/ttyS0 baud=13 iofd=0x4b
[Sep 22 16:54:39] WARNING[10871]: app_rpt.c:11140 serial_remote_io: Serial device not responding on node 2555
[Sep 22 16:54:39] NOTICE[10871]: app_rpt.c:11117 serial_remote_io: ioport=/dev/ttyS0 baud=13 iofd=0x4b
[Sep 22 16:54:39] NOTICE[10733]: app_rpt.c:10331 handle_link_data: @@@@ node 2298 recieved node list L T2023,T2061,T2459,T2010,T2011,T2393,T2480,T2481 from node 2000
[Sep 22 16:54:40] WARNING[10871]: app_rpt.c:11140 serial_remote_io: Serial device not responding on node 2555
[Sep 22 16:54:40] NOTICE[10871]: app_rpt.c:11117 serial_remote_io: ioport=/dev/ttyS0 baud=13 iofd=0x4b
[Sep 22 16:54:41] WARNING[10871]: app_rpt.c:11140 serial_remote_io: Serial device not responding on node 2555
I have just tried with a belkin USB serial dongle and get the exact same errors. I can see data going out on the TX light but no rx light ever flashes. It's like the radio is not talking to the system. As a test I tried the Kenwood RCP software with the same USB dongle and it works file.
Am I supposed to set the baud rate somewhere?
Thanks & 73,
Scott KB2EAR
----- Original Message ----- From: "Scott Weis" <kb2ear@kb2ear.net>
To: "app_rpt users list" <app_rpt-users@qrvc.com>
Sent: Tuesday, September 22, 2009 5:01 PM
Subject: [App_rpt-users] (no subject)
remote=tm271
(optional)
(optional)
duplex=0
updates
      > priority = mine
stack
stack
stack
port /dev/ttyS0
from node 2000
App_rpt-users@qrvc.com
Thanks & 73,
Scott KB2EAR
remote=tm271
(optional)
(optional)
duplex=0
and
updates
      > priority = mine
stack
stack
stack
port /dev/ttyS0
node
from node 2000
The baud rate is fixed in the app_rpt s/w.
The problem is very likely to be in the interface. What are you using
for an interface? Note the interface is not the usb to serial converter,
and it is not the pre-made up Kenwood serial cable either. It is usually
a homebrew circuit which merges the output from the sound fob and the
serial port together, oh, and it requires power from the modified FOB as
well.
Please refer to the interface circuit here:
http://images.qrvc.com/usb2tmg707.pdf
Steve
WA6ZFT
Isn't that circuit only required because the TM-G707 uses the same connector for programming as for the audio and COR?
Scott
----- Original Message ----- From: "Stephen Rodgers" <sales@qrvc.com>
To: "Scott Weis" <kb2ear@kb2ear.net>
Cc: "app_rpt users list" <app_rpt-users@qrvc.com>
Sent: Tuesday, September 22, 2009 9:50 PM
Subject: Re: [App_rpt-users] TM-271 remote base setup
Thanks & 73,
Scott KB2EAR
remote=tm271
(optional)
(optional)
duplex=0
and
updates
      > priority = mine
stack
stack
stack
port /dev/ttyS0
node
from node 2000
well.
Steve
WA6ZFT
No, in the case of the tm-271 the interface IS the standard serial one
that connects thru the mic cable.
Date: Tue, 22 Sep 2009 18:50:41 -0700
To: kb2ear@kb2ear.net
CC: app_rpt-users@qrvc.com
flashes. It’s like the radio is not talking to the system. As a test I
Thanks & 73,
Scott KB2EAR
To: “app_rpt users list” app_rpt-users@qrvc.com
remote=tm271
(optional)
(optional)
duplex=0
statpost_program=/usr/bin/wget,-q,–output-document=/dev/null ; Program
and
updates
– Accepting AUTHENTICATED call from 172.31.1.164:
priority = mine
– Executing [2555@radio-phone:1] Answer(“IAX2/pbx-5488”, “”) in new
stack
– Executing [2555@radio-phone:2] Wait(“IAX2/pbx-5488”, “2”) in new
stack
– Executing [2555@radio-phone:3] Rpt(“IAX2/pbx-5488”, “2555|P”) in new
stack
– Re-Loading config for repeater 2555
== Parsing ‘/etc/asterisk/rpt.conf’: Found
– rpt (Rx) initiating call to Radio/usb1 on Radio/usb1
== Parsing ‘/etc/asterisk/usbradio_tune_usb1.conf’: Found
port /dev/ttyS0
node
from node 2000
well.
Steve
WA6ZFT
Thanks & 73,
Scott KB2EAR
remote=tm271
(optional)
(optional)
duplex=0
and
updates
      > priority = mine
stack
stack
stack
port /dev/ttyS0
node
from node 2000
well.
Steve
WA6ZFT
Oops. I screwed up!
I don't know how I got stuck on TMG-707 vs TM-271.
The TM-271 has a dedicated serial port so please disregard my confusing
message....
Steve
WA6ZFT
Anyway, Does anyone out there have a working config for the tm271 that they would be willing to share? I can provide SSH access for debugging. at this point I'm stuck.
Thanks & 73
Scott KB2EAR
To: "Jim Duuuude" <telesistant@hotmail.com>
Cc: <kb2ear@kb2ear.net>; "app_rpt mailing list" <app_rpt-users@qrvc.com>
Sent: Tuesday, September 22, 2009 11:07 PM
Thanks & 73,
Scott KB2EAR
remote=tm271
(optional)
(optional)
duplex=0
and
updates
      > priority = mine
stack
stack
stack
port /dev/ttyS0
node
from node 2000
well.
Steve
WA6ZFT
Oops. I screwed up!
message....
Steve
WA6ZFT
I have now tried this on 3 different machines, every one of them fails the same way. Does anyone actually have a Kenwood TM-271a working with version 0.203 9/12/2009 of app_rpt.c?
Scott
To: <sales@qrvc.com>; "Jim Duuuude" <telesistant@hotmail.com>
Cc: "app_rpt mailing list" <app_rpt-users@qrvc.com>
Sent: Tuesday, September 22, 2009 11:28 PM
point I'm stuck.
Thanks & 73
Scott KB2EAR
same
file.
Thanks & 73,
Scott KB2EAR
the
remote=tm271
(optional)
entries
(optional)
duplex=0
Program
and
status
updates
      > priority = mine
new
stack
stack
new
stack
Loaded
serial
port /dev/ttyS0
Tracepoint
Tracepoint
send_usb_txt
Serial
Serial
Serial
node
from node 2000
Serial
Serial
well.
Steve
WA6ZFT
Oops. I screwed up!
message....
Steve
WA6ZFT
It was suggested that I capture the output of the computer trying to talk to the TM-271a. So this is what I get:
VF 0146520000,0,0,0,0,0,0,12,00,000,00600000,0,0
I'm sure that there is something missing. I have tried connecting the PC running the MCP program and It is sending some sort of unprintable character to get the radio in to serial programming mode. But it stops there.
Anyone have any suggestions for a protocol analyzer (Free/Cheap)?
Any ideas out there at all?
Thanks & 73,
Scott KB2EAR
To: "app_rpt mailing list" <app_rpt-users@qrvc.com>
Sent: Wednesday, September 23, 2009 12:46 PM
Scott
they
point I'm stuck.
Thanks & 73
Scott KB2EAR
same
I
file.
Thanks & 73,
Scott KB2EAR
the
remote=tm271
port
(optional)
entries
(optional)
duplex=0
Program
and
status
updates
do_el_directory:
      > priority = mine
new
stack
new
stack
in
new
stack
Loaded
serial
port /dev/ttyS0
Tracepoint
Tracepoint
send_usb_txt
Serial
Serial
Serial
node
from node 2000
Serial
Serial
converter,
usually
as
well.
Steve
WA6ZFT
Oops. I screwed up!
message....
Steve
WA6ZFT
Thanks & 73,
Scott KB2EAR
Scott
they
this
point I'm stuck.
Thanks & 73
Scott KB2EAR
same
I
file.
Thanks & 73,
Scott KB2EAR
have
the
channel
remote=tm271
port
(optional)
entries
(optional)
duplex=0
Program
and
status
updates
do_el_directory:
      > priority = mine
new
stack
new
stack
in
new
stack
Loaded
serial
port /dev/ttyS0
Tracepoint
Tracepoint
send_usb_txt
Serial
Serial
Serial
node
from node 2000
Serial
Serial
converter,
usually
as
well.
Steve
WA6ZFT
Oops. I screwed up!
message....
Steve
WA6ZFT
What version of app_rpt.c are you running?
I'm no the expert on the TM-271 code or its protocol, but after a brief
look, it seems to me like the code is attempting send a VF command
(which it should do) and is never receiving an acknowledge response from
the radio! This explains the 5 VF attempts seen in the capture as the
Kenwood retry count is set to 5 in the code. You should be able to
confirm this by going in to the Asterisk CLI and sending the CLI command:
rpt debug level 5
Then connect to the remote base and capture the cli output.
Another thing to try is to monitor the serial data going from the radio
back to the PC and try to see if you can see any acknowledgement data
being transmitted by the radio.
Steve
WA6ZFT
I can see when the commands are given that there are no responses from the radio. Like I said I think there is a sequence missing, I believe there should be some control character that wakes up the radio for serial data, which is not being sent from app_rpt.c. I am running version 0.203 9/12/2009. Here is the output of the debug:
[Sep 29 11:56:13] WARNING[12195]: chan_usbradio.c:1436 hidthread: Loaded parameters from usbradio_tune_usb1.conf for device usb1 .
[Sep 29 11:56:13] NOTICE[12194]: app_rpt.c:4040 openserial: Opened serial port /dev/ttyS0
[Sep 29 11:56:13] NOTICE[12205]: app_rpt.c:4230 send_usb_txt: send_usb_txt SETFREQ 0.0 0.0 0.0 0.0 L
[Sep 29 11:56:13] NOTICE[12205]: app_rpt.c:11117 serial_remote_io: ioport=/dev/ttyS0 baud=13 iofd=0x46
[Sep 29 11:56:14] WARNING[12205]: app_rpt.c:11140 serial_remote_io: Serial device not responding on node 2555
[Sep 29 11:56:14] NOTICE[12205]: app_rpt.c:11117 serial_remote_io: ioport=/dev/ttyS0 baud=13 iofd=0x46
[Sep 29 11:56:15] WARNING[12205]: app_rpt.c:11140 serial_remote_io: Serial device not responding on node 2555
[Sep 29 11:56:15] NOTICE[12205]: app_rpt.c:11117 serial_remote_io: ioport=/dev/ttyS0 baud=13 iofd=0x46
[Sep 29 11:56:16] WARNING[12205]: app_rpt.c:11140 serial_remote_io: Serial device not responding on node 2555
[Sep 29 11:56:16] NOTICE[12205]: app_rpt.c:11117 serial_remote_io: ioport=/dev/ttyS0 baud=13 iofd=0x46
[Sep 29 11:56:17] WARNING[12205]: app_rpt.c:11140 serial_remote_io: Serial device not responding on node 2555
[Sep 29 11:56:17] NOTICE[12205]: app_rpt.c:11117 serial_remote_io: ioport=/dev/ttyS0 baud=13 iofd=0x46
[Sep 29 11:56:18] WARNING[12205]: app_rpt.c:11140 serial_remote_io: Serial device not responding on node 2555
[Sep 29 11:56:18] NOTICE[12205]: app_rpt.c:6616 wait_interval: Delay interval = 1000
[Sep 29 11:56:19] NOTICE[12205]: app_rpt.c:6620 wait_interval: Delay complete
    -- <Zap/pseudo-94643657> Playing 'rpt/invalid-freq' (language 'en')
----- Original Message ----- >
rpt debug level 5
Steve
WA6ZFT
I have had a minor break through. I have found that if I type the string:
VF 0162550000,0,2,0,1,0,0,22,22,000,00600000,0,0
by hand the radio changes frequency. But if I paste the same exact string the radio does not change frequency. This makes me think that perhaps there is a buffer overflow on the radio. I have tried software flow control and it does not work. Nor does hardware flow control.
I also found that the com parameters need to be 9600 Baud, 8 bits, no parity, 1 stop bit
I am not a c guy so I am not going to be able to work this one out. Any ideas??
Scott
Sent: Tuesday, September 29, 2009 12:02 PM
port /dev/ttyS0
interval = 1000
complete
rpt debug level 5
Steve
WA6ZFT
