(no subject)
Something just happened tonight. Sytem started running sluggish, iaxrpt stopped being able to connect, took a look and found about 30 instances of wget running as in updating the stats server. Netstat revealed the connections. This was about 10:30PM Central time.
I commented out the two lines that do the updating in rpt.conf.
Has anyone ever seen this? This is a no moving parts Limey Linux CF image for D945
GeorgeC
W2DB
Cedar Park, TX
Node 2360
424835 el
Yes we are quite aware of this problem. The stats server is down and
it causes this cascading “log jam” effect.
first killall -9 wget
In rpt.conf, change the line(s) that invoke(s) wget, adding --timeout=15,–tries=1
after the -v and before the --output-document= (all separted by commas).
Then restart asterisk and it will be happy.
Date: Wed, 27 May 2009 04:13:12 +0000
To: app_rpt-users@qrvc.com
Subject: [App_rpt-users] (no subject)
for D945
GeorgeC
W2DB
Cedar Park, TX
Node 2360
424835 el
App_rpt-users@qrvc.com
The Status is down and should be back up today. The fiber line from Cox went down and they are looking at it today.
David
for D945
GeorgeC
W2DB
Cedar Park, TX
Node 2360
424835 el
Thank you, David
73’s KE6UPI
