No PL Tone
I am trying to get the PL tone of 100.0 hz to work on my GE Mastr II
repeater. I'm using a URI interface on a laptop running Dail software.
Everything is working other than the tones. Here is my rpt.conf and
usbradio.conf. Thanks for any help.
Chris Viningre
70 W. Roadrunner
Salt Flat, Texas 79847
C:(915) 504-1510
chrisviningre@gmail.com
Amateur Radio Operator: WS5B
Radio Repeater configuration file (for use with app_rpt)
; Your Repeater
[43934] ; Change this to your assigned node number
rxchannel=Radio/usb43934
duplex=2
erxgain=-3
etxgain=3
;controlstates=controlstates
scheduler=schedule43934
morse=morse43934
macro=macro43934
functions=functions43934
phone_functions=functions43934
link_functions=functions43934
telemetry=telemetry
wait_times=wait-times
context = radio
callerid = "Repeater" <0000000000>
idrecording = |iWS5B
accountcode=RADIO
hangtime=1000
; Usbradio channel driver Configuration File
[general]
[usb43934]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
txctcssdefault=100.0
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=usb
ctcssfrom=usb
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=no
txmixa=composite
txmixb=no
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
Are you trying to get the pl tone to decode and encode?
If you want it to decode tones, you must be connected to vol/Sq hi (discriminator) signal on the master II for receive audio input. And you must set rxdemod to flat in the usbradio.conf file.
Also In usbradio.conf, set txmixa to voice and connect to the mic input.
set txmixb to tone and connect to the tx pl tone input on the exciter.
Recal all audio levels.
hope this helps.
cheers!
Jon VA3RQ
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
WS5B - Callsign Lookup by QRZ Ham Radio
Chris Viningre | ReverbNation
; Your Repeater
duplex=2
erxgain=-3
etxgain=3
morse=morse43934
macro=macro43934
telemetry=telemetry
context = radio
callerid = "Repeater"<0000000000>
accountcode=RADIO
hangtime=1000
[general]
[usb43934]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=usb
ctcssfrom=usb
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=no
txmixa=composite
txmixb=no
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
I tried the settings and still no tone squelch. This is what I get
when I do a radio-tune-menu. I dont know if this would help.
Please enter your selection now: 4
INFO: RX CTCSS ADJUST START.
target=2400 tolerance=100
tries=0, setting=1.000000, meas=0
tries=1, setting=8.000000, meas=0
tries=2, setting=8.000000, meas=0
tries=3, setting=8.000000, meas=0
tries=4, setting=8.000000, meas=0
tries=5, setting=8.000000, meas=0
tries=6, setting=8.000000, meas=0
tries=7, setting=8.000000, meas=0
tries=8, setting=8.000000, meas=0
tries=9, setting=8.000000, meas=0
tries=10, setting=8.000000, meas=0
tries=11, setting=8.000000, meas=0
DONE tries=12, setting=8.000000, meas=0.00
ERROR: RX CTCSS GAIN ADJUST FAILED.
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
hope this helps.
cheers!
Jon VA3RQ
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
; Your Repeater
duplex=2
erxgain=-3
etxgain=3
morse=morse43934
macro=macro43934
telemetry=telemetry
context = radio
accountcode=RADIO
hangtime=1000
[general]
[usb43934]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=usb
ctcssfrom=usb
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=no
txmixa=composite
txmixb=no
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
Ok make sure you have the vol/Sq hi line connected to pin 21 "mic in " on the URI. and ground to any of the ground pins on the URI.
If you are not sure you are connected to vol/SQ hi on the mastr II, you can usually find it on the hi side of the Squelch pot on the tray that folds down (if you have the station).
From below it looks like there is no receive audio connected to the URI.
Jon RQ
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
hope this helps.
cheers!
Jon VA3RQ
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
; Your Repeater
duplex=2
erxgain=-3
etxgain=3
morse=morse43934
macro=macro43934
telemetry=telemetry
context = radio
accountcode=RADIO
hangtime=1000
[general]
[usb43934]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=usb
ctcssfrom=usb
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=no
txmixa=composite
txmixb=no
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
First of all, you need carrierfrom=dsp not usb.
carrierfrom=dsp ; Carrier Detect Source ; Options - no,usb,usbinvert,dsp,vox ; no - no carrier detection at all ; usb - via USB radio adapter COR connection ; usbinvert - same as above but inverted polarity. ; dsp - from RX noise using dsp methods ; vox - voice activated via RX audio
Take a look at:
https://allstarlink.org/usbradio.html
Robert A. Poff
Loganville, Pa
Sent: Sat Nov 05 17:19:25 EDT 2016
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] No PL Tone
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
[https://www.qrz.com/db/ws5b](https://www.qrz.com/db/ws5b)
[http://www.reverbnation.com/chrisviningre](http://www.reverbnation.com/chrisviningre)
; Your Repeater
number
duplex=2
erxgain=-3
etxgain=3
morse=morse43934
macro=macro43934
telemetry=telemetry
context = radio
accountcode=RADIO
hangtime=1000
File
[general]
[usb43934]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=usb
ctcssfrom=usb
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=no
txmixa=composite
txmixb=no
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
To unsubscribe from this list please visit [http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users) and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options
button"
</details>
I may have been unclear on the problem. I am not getting any tone
squelch. The repeater is working fine other then that. I have
tried these settings and still no luck. Thanks for all the help.
Chris
Take a look at:
    [https://allstarlink.org/usbradio.html](https://allstarlink.org/usbradio.html)
Robert A. Poff
Loganville, Pa
To:
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
; Your Repeater
number
duplex=2
erxgain=-3
etxgain=3
morse=morse43934
macro=macro43934
telemetry=telemetry
context = radio
accountcode=RADIO
hangtime=1000
File
[general]
[usb43934]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=usb
ctcssfrom=usb
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=no
txmixa=composite
txmixb=no
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
To unsubscribe from this list please visit and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options
button"
Subject:
chrisviningre@gmail.comhttps://www.qrz.com/db/ws5bhttp://www.reverbnation.com/chrisviningre
I may have been unclear on the problem. I can not get the
repeater to tone squelch. It is always open. The repeater is
working fine other then that. I have tried these settings and
Chris
Take a look at:
Robert A. Poff
Loganville, Pa
To:
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
; Your Repeater
number
duplex=2
erxgain=-3
etxgain=3
morse=morse43934
macro=macro43934
telemetry=telemetry
context = radio
accountcode=RADIO
hangtime=1000
File
[general]
[usb43934]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=usb
ctcssfrom=usb
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=no
txmixa=composite
txmixb=no
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
button"
Subject:
Personally I wouldn’t bother with using the tone boards in the MII.
On both of mine, I just pulled VOL/SQL HI from the backplane. Then let the usbradio DSP do it all.
On the MIIe (direct FM exciter) I was able to feed both CG and voice into the CG input of the exciter. Measured it to be flat to 8 KC. Then let usbradio do the pre-emphasis, CG encode/decode, and de-emphasis.
On the regular MII (phase modulated exciter), again all DSP. Voice into the exciter mic input, CG encode to the CG input. With the exciter doing the pre-emphasis.
Robert A. Poff
Loganville, Pa
Take a look at:
Robert A. Poff
Loganville, Pa
To:
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
; Your Repeater
number
duplex=2
erxgain=-3
etxgain=3
morse=morse43934
macro=macro43934
telemetry=telemetry
context = radio
accountcode=RADIO
hangtime=1000
File
[general]
[usb43934]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=usb
ctcssfrom=usb
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=no
txmixa=composite
txmixb=no
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
button"
Subject:
Good catch by Robert.
I think you have to have both carrierfrom and ctcssfrom set to dsp
in usbradio.conf. for the tone decoding to work.
Subject:
Take a look at:
Robert A. Poff
Loganville, Pa
Chris Viningre
To:
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
; Your Repeater
number
duplex=2
erxgain=-3
etxgain=3
morse=morse43934
macro=macro43934
telemetry=telemetry
context = radio
accountcode=RADIO
hangtime=1000
File
[general]
[usb43934]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=usb
ctcssfrom=usb
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=no
txmixa=composite
txmixb=no
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
button"
Subject:
That was it. Thank you to everyone that tought this old dog some new
tricks. Y’all are great!
Chris
On 11/06/2016 05:22 PM, REDBUTTON_CTRL
  On 11/6/2016 6:22 PM, Bob Poff wrote:
      Personally I wouldn't bother with using the tone boards in
the MII.
Robert A. Poff
Loganville, Pa
Chris Viningre
Sent: Sun Nov 06 16:19:11 EST 2016
To: Bob Poff
Cc:
Re: [App_rpt-users] No PL Tone
Chris
Subject:
Take a look at:
Robert A. Poff
Loganville, Pa
Chris Viningre
To:
Chris Viningre
70 W. Roadrunner
C:(915) 504-1510
; Your Repeater
number
duplex=2
erxgain=-3
etxgain=3
morse=morse43934
macro=macro43934
telemetry=telemetry
context = radio
accountcode=RADIO
hangtime=1000
File
[general]
[usb43934]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
rxctcssfreqs=100.0
txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=usb
ctcssfrom=usb
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=no
txmixa=composite
txmixb=no
invertptt=0
duplex=1
rxondelay=0
rxnoisefiltype=0
eeprom=0
button"
Subject:
App_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usershttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usersApp_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usershttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
