No node connections after update
Asterisk Version: 2:22.8.2+asl3-3.8.3-1.deb13
ASL3 Version: 3.17-1.deb13
RPI 3B+
modified cm108 soundcard
DVSwitch server installed but not connected
I have just updated using the updater in the ASL terminal. At first I could not access any web pages but found Apache2 disabled. I enabled it and now the pages load. The problem is that I can no longer connect to other nodes and the cannot connect to me I have restarted several times with no change. I have not powered down and started from cold.
Where do I look for a change that did not happen that should have or a change that did happen that should not have?
Thanks, Eric _ AJ4QR
Inquiry
