Morning all,
I’ve been trying to get a simplex allstarlink node to work as a remote node to my Yaesu Fusion DR-1X for a while now and I don’t seem to get past this hurdle.
The allstarlink is a Rpi3 attached to a Kenwood TK-761G.
Allstar node sends audio to the Kenwood which in turn sends it to the repeater receive side … this works fine as the node perfectly announces the time on the hour.
Simpleusb seem to be configured correctly as the audio bar in (simpleusb configuration option 2) moves correctly and stays around 3KHz while audio is received from the Kenwood into the USB.
But, here it comes…when I connect to allstarlink (or echolink for that matter) node number 55553, I can in supermon2 see the node line receiving (COS-Detected is displayed and line node line and the line turns light blue).
A second or so after unkey the connected node line turns dark blue, the line above (my node) turns light yellow and PTT-Detected is displayed.
Now for the but, …but no audio is sent to the repeater.
What am I missing? I’ve done this successfully with baofeng 888 and with Kevin RA-35 on another install at a repeater where internet is available locally.
This one has me stumped, so anyone that has any insight to what I’m doing wrong, please reach out to me and give me an idea to where things are not set right. the fact that hourly the node execute the saytime.pl successfully tell me audio flows from node to radio to repeater, but why not when connected to a parrot node?
