no audio from URI
good morning,
i connect a headphone to the URI so we don`t need to search the problem on the Motorolas…
73…
Von: David Morley [ab8tn1@cox.net]
Gesendet: Dienstag, 3. Juni 2014 07:14
An: torben@klimt-online.com
Betreff: Re: [App_rpt-users] no audio from URI
Are the GM 360s the same as the GM 300s? Do they have 16 pin connectors
Sent from my iPhone
On Jun 2, 2014, at 2:07 PM, “torben@klimt-online.comtorben@klimt-online.com wrote:
Hi all,
i think i have a little blackout L
I would like to set up a repeater with 2 GM360
- SQL detect is ok
- NF to another connectet repeater is ok
- DTMF is ok (looks good on console)
- PTT is ok
BUT there is no audio out from the URI on Port 22 and or 23 L
On a windows machine the URI works fine but on the asterisk there is no output
Any ideas ?
greetings
Hi all,
- SQL detect is ok - NF to another connectet repeater is ok - DTMF is ok (looks good on console) - PTT is ok
Any ideas ?
greetings
i take this box
http://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/dc3217iye-product-brief.pdf
73 de tom dh6mbt
Von: app_rpt-users-bounces@ohnosec.org [app_rpt-users-bounces@ohnosec.org] im Auftrag von kk6ecm [kk6ecm@gmail.com]
Gesendet: Dienstag, 3. Juni 2014 12:59
An: App_rpt-users@ohnosec.org
I’m not sure of your issue, but your experience sounds like mine when I attempted to use a computer with a newer chipset, incompatible withe CentOS 5.10. That was Intel chipset NM 70. When I used a mother board with the older Intel chipset NM 10, I hade no audio issues. I discovered the issue when using DMK Engineering uridiag software on the ACID build (see URI FAQ on the DMK website re uridiag and loopback testing).
Bob
kk6ecm
Sent from iPad
On Jun 2, 2014, at 11:01 PM, “torben@klimt-online.comtorben@klimt-online.com wrote:
good morning,
73…
Sent from my iPhone
Hi all,
- SQL detect is ok
- PTT is ok
Any ideas ?
greetings
Hi all,
Any ideas ?
greetings
Now i tried 3 different computers with 2 URI-Boards and 3 installs
  •      SQL detect by DSP -> ok
  •      DTMF reading -> ok
  •      Transmitting by PTT -> ok
  •      Sending audio -> NO
I have headphones connectet direct to the URI on Pins 13 (GND) and 22/23 → no nothing L L
Von: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-bounces@ohnosec.org] Im Auftrag von kk6ecm
Gesendet: Dienstag, 3. Juni 2014 14:11
Again, I’m not sure if it is your issue, but the chipset used in your board is of the same family as the one I seemed to have difficulty. When I chose a board with an older generation chipset (NM10, and not the 7x series), the audio worked good.
Bob
kk6ecm
Sent from iPad
On Jun 3, 2014, at 4:19 AM, “torben@klimt-online.comtorben@klimt-online.com wrote:
i take this box
73 de tom dh6mbt
Bob
kk6ecm
Sent from iPad
good morning,
73…
Sent from my iPhone
Hi all,
- SQL detect is ok
- PTT is ok
Any ideas ?
greetings
So if you do something like 'radio tune txvoice 500', you hear nothing
in the headphones?
Out of curiosity, try connecting the headphones to the onboard audio
in the computer (assuming it has such) and repeat the test....
When I first started playing with ACID in a VirtualBox VM, I seemed to
have no audio out. I then disabled VBox audio for the VM, and it
started working. I didn't spend any more time analysing it, so it may
have started working for some other reason. I've since installed on a
"real" computer, and disabled the onboard audio via BIOS setup there,
and everything is working FB there.
73,
    ~iain / N6ML
On Tue, Jun 3, 2014 at 11:51 AM, torben@klimt-online.com <torben@klimt-online.com> wrote:
- SQL detect by DSP -> ok
- DTMF reading -> ok
- Transmitting by PTT -> ok
- Sending audio -> NO
I have headphones connectet direct to the URI on Pins 13 (GND) and 22/23 ->
no nothing L L
Again, I'm not sure if it is your issue, but the chipset used in your board
audio worked good.
Bob
kk6ecm
Sent from iPad
On Jun 3, 2014, at 4:19 AM, "torben@klimt-online.com" > <torben@klimt-online.com> wrote:
i take this box
73 de tom dh6mbt
________________________________
I'm not sure of your issue, but your experience sounds like mine when I
Bob
kk6ecm
Sent from iPad
On Jun 2, 2014, at 11:01 PM, "torben@klimt-online.com" > <torben@klimt-online.com> wrote:
good morning,
the Motorolas....
73...
Sent from my iPhone
On Jun 2, 2014, at 2:07 PM, "torben@klimt-online.com" > <torben@klimt-online.com> wrote:
Hi all,
<!--[if !supportLists]-->- <!--[endif]-->SQL detect is ok
<!--[if !supportLists]-->- <!--[endif]-->NF to another connectet
repeater is ok
<!--[if !supportLists]-->- <!--[endif]-->DTMF is ok (looks good on
console)
<!--[if !supportLists]-->- <!--[endif]-->PTT is ok
output
Any ideas ?
greetings
ohnosec.org
ohnosec.org and scroll down to
the bottom of the page. Enter your email address and press the "Unsubscribe
or edit options button"
ohnosec.org
ohnosec.org
Bob
kk6ecm
Sent from iPad
i take this box
73 de tom dh6mbt
Bob
kk6ecm
Sent from iPad
good morning,
73…
Sent from my iPhone
Hi all,
- SQL detect is ok
- PTT is ok
Any ideas ?
greetings
IT WORKS NOW
I tried the next pc (an older one) and it works fine without any config changes. It`s short before midnight and I must go to work tomorrow L
I will look the next days which CPUs and Chipsets I tried and doesn`t work and which one work now ok ?
Good n8 tom dh6mbt
Gesendet: Dienstag, 3. Juni 2014 23:13
Try amplifying the output of the URI in order to drive the speaker. If that does not work, I’d test the URI using a loopback connector and uridiag down loaded from http://www.dmkeng.com/images/URI-FAQs.pdf
Make sure Asterisk is stopped when uridiag is used. Service asterisk stop on the Linux command line. This is not a test to determine URI health, but the ability of the ACID build on your computer, and the ability to send audio to the URI.
Bob
kk6ecm
Sent from iPad
On Jun 3, 2014, at 2:51 PM, “torben@klimt-online.comtorben@klimt-online.com wrote:
Bob
kk6ecm
Sent from iPad
i take this box
73 de tom dh6mbt
Bob
kk6ecm
Sent from iPad
good morning,
73…
Sent from my iPhone
Hi all,
- SQL detect is ok
- PTT is ok
Any ideas ?
greetings
hi all,
here the missing information for the machines who don`t work :frowning:
is there any ppossibility to run it in the future ? cause the INtel NUC is very nice :wink:
greetings tom dh6mbt
PC1:
Modell : Intel NUC DC321IYE
Homepage : http://www.intel.com/content/www/us/en/nuc/nuc-kit-dc3217iye.html
Processor: Intel Core i3 processor
Chipset : Intel QS77 Express Chipset
PC2 and 3:
Modell : Fujitsi Lifebook E780
Homepage : http://globalsp.ts.fujitsu.com/dmsp/Publications/public/db_profnb_lifebook_e780_de.pdf
Processor: Intel Core i5 processor
Chipset : Intel QM57
Von: app_rpt-users-bounces@ohnosec.org [app_rpt-users-bounces@ohnosec.org] im Auftrag von torben@klimt-online.com [torben@klimt-online.com]
Gesendet: Dienstag, 3. Juni 2014 23:33
An: kk6ecm; App_rpt-users@ohnosec.org
IT WORKS NOW
Good n8 tom dh6mbt
Bob
kk6ecm
Sent from iPad
Bob
kk6ecm
Sent from iPad
i take this box
73 de tom dh6mbt
Bob
kk6ecm
Sent from iPad
good morning,
73…
Sent from my iPhone
Hi all,
- SQL detect is ok
- PTT is ok
Any ideas ?
greetings
IT WORKS NOW
Good n8 tom dh6mbt
Bob
kk6ecm
Sent from iPad
Bob
kk6ecm
Sent from iPad
i take this box
73 de tom dh6mbt
Bob
kk6ecm
Sent from iPad
good morning,
73…
Sent from my iPhone
Hi all,
- SQL detect is ok
- PTT is ok
Any ideas ?
greetings
yes i disabled internal audio by the notebook, the intel nuc don`t have an internal audio
Gesendet: Mittwoch, 4. Juni 2014 11:42
Have you tried Iain’s suggestion to disable the internal audio? See his email.
Bob
kk6ecm
Sent from iPad
On Jun 4, 2014, at 5:24 AM, “torben@klimt-online.comtorben@klimt-online.com wrote:
hi all,
PC1:
PC2 and 3:
IT WORKS NOW
Good n8 tom dh6mbt
Bob
kk6ecm
Sent from iPad
Bob
kk6ecm
Sent from iPad
i take this box
73 de tom dh6mbt
Bob
kk6ecm
Sent from iPad
good morning,
73…
Sent from my iPhone
Hi all,
- SQL detect is ok
- PTT is ok
Any ideas ?
greetings
