I’m having a issue,
I have an Alinco DR 435 UHF radio with the Repeater-Buildier RIM Lite. Everything on the Pi and the Radio is programmed correctly , the levels are fine, the DTMF tones seem to be decoding and showing up . The problem is when the radio hears the DTMF tones , the Pi is not responding to ALS . I get no tones if I put it Test using simple USB to test . DTMF tones are not being recognized somewhere,as I said I see it when I select the Asterix mode.
The Pi is periodically holding up the transmitter for a time which tells me it’s transmitting my node ID and Callsign…. But there is no audio out the radio I’m listening too. No command ack is being heard.
Question is , is there a command line that has to be added to the Psudeo or something turned off or on in the Simple USB settings……
I’m frustrated…
The Node is working and I see ho many times its keyed up etc,so it is connected,I can’t connect to anyone, or hear the command audio from the Pic on the radio transmit…
Any suggestions?…
N7COX
