he changed his ip address i blocked the new one
the next step will be to remove allstar from all outside connections
i have told him several times to stop connecting
feel free to tell him to go away if he changes his ip address again
On Wednesday, August 5, 2020, 08:19:10 PM PDT, David McGough via AllStarLink Discussion Groups [email protected] wrote:
| David_McGough
August 6 |
Stew,
Carefully check your /etc/asterisk/rpt.conf files and confirm that you’ve got the correct node numbers for the stanzas. So, a stanza labeled [510560] for the first node and [510561] for the second. Also, confirm that the /etc/asterisk/iax.conf file has the corresponding registration statement for each node.
73, David KB4FXC
In Reply To
| Stew_L
August 5 |
Hi David, I changed the password for both nodes. Each node always shows up or down correctly on the Allstar Link Node List. When I have no nodes up, the Node Map shows 51056, and that it is down. When I have 510560 up by itself, the Node Map shows 510560 is up When I have 510561 up by itself, t…
Previous Replies
| Stew_L
August 5 |
Hi David,
When I have 510561 up by itself, the Node Map shows 510560 is up.
When I have both nodes up, the Node Map shows 510560 is up.
510561 never shows up on the Node Map.
If I change the setting to view Online Nodes only, it shows 510560 is up.
If I change the setting to view All nodes, it shows 51056 is offline.
Both nodes are working correctly.
Stew
KB3JRB
| Stew_L
August 5 |
Thanks David,
Fixed. Thanks.
This shows why one should copy & paste. When I wrote down my password, my “6” looked like a “b.” Your hint of changing the password led me to checking it, when I saw that I entered one character incorrectly. I fixed it, and now my nodes show up on the Allstar Link Node List with a green background.
I am wondering why only one node shows up on the Allstar Node map so far.
Of course, I backed up my SD cards.
Thanks.
Stew
KB3JRB
| David_McGough
August 5 |
Strange…No idea. It might be worth going to the www.allstarlink.org website and changing the password for node 510560. Then, try the new password.
| Stew_L
August 5 |
Hi David,
The output from my “iax2 show registry” command is below.
Stew
KB3JRB
| David_McGough
August 5 |
Hi Stew,
The use of an “=” sign versus “=>” is interchangeable in AllStar / HamVoIP.
The (NodeNumber)#(BindPort) notation is custom and optional for HamVoIP. In HamVoIP, if you omit the #(BindPort) part, your node’s perceived outbound port (as shown with “iax2 show registry”) is used and advertised.
What does the output from your “iax2 show registry” command show??
73, David KB4FXC
