NNX Node Numbers define City/State per Node instead of per Server
Any possibility to have in the future the ability of defining the City & State of NNX Node Numbers? Right now it only looks like you can define the City/State under the Server tab. Would be nice to have the ability to define this under the Node specifics tab for each Node.
When the database was designed there was no thought that the node could be some place other than the same location as the server. Opps! The db schema and code around it needs a significant modification to correct that problem. That is something we want to do someday.
The work around is to create a virtual server on the portal for each location of node(s). It’s not a problem to create as many virtual servers as needed. Be sure to use the same IAX port as the actual server.
Thanks Tim!
Oddly that worked…
I just moved the node over to another server I have setup in the system, and everything is working as it should.
