New user needs help!
Good day to all! I am new to ASL. I applied for a node number which i have working (63479) when i applied the system generated 2 extensions numbers (634790 and 634791) Both these numbers appears on the node list. My problem is that i do not see the original issued number (63479) on the node list. What do I need to do to make the original node number appear on the list? Please give me step by step instructions because i am not very familiar with this system.
Tank you in advance.
Aldo VA3AG
When you switched to NNX (the node number extensions) your 63479 node number will no longer be available. See NNX - AllStarLink Wiki for more info.
Thank you, that did the trick!
I appriciate the help!
