Hi all. I’m brand new to Allstar, and today I spun up a node on a cloud server running ASL.
I’ve got it configured and working, and I can dial in from IAX clients, and I can successfully use the allstar system when I’m connected.
The problem comes when I disconnect my IAX client, but leave my node connected to another node. For as long as the nodes are connected, I can’t dial back in.
I dial the node number, I hear the node number read out to me, then I’m disconnected. I get the following error output in the Asterisk CLI whenever is happens:
[May 30 23:16:38] NOTICE[747]: app_rpt.c:22668 rpt_exec: Radio Channel Busy.
If I disconnect the other node I’m connected to before I hang up, I can dial back in. And if I use an external management tool to disconnect the node I can dial back in.
Is this normal behavior?
I hadn’t noticed this in my own testing initially as I was manually disconnecting things when I was finished. But today, someone connected to my node and I had to kick them off before I could dial back in. Which lead me to testing and discovering that I get the same “problem” whenever a node is connected to my node.
Obviously this is in the cloud, there’s no real radio involved, and I’m using purely IAX access.
Any pointers would be appreciated. And I can provide any logs or output that might be useful.
