We’re moving the URL astdb.php uses to fetch the “Node Information” database. Allmon Web site operators and users with Allmon installed on your node should edit the astdb.php URL line to show:
$url = "http://allmondb.allstarlink.org";.
The reason for this move is we are preparing to retire the original allstarlink.org server. No date has been set to but we hope to shut it down soon. Please update at your next opportunity. Thanks!
A change will be made tonight to implement RRDNS for the new Allmon db URL, http://allmondb.allstarlink.org. If the change is successful we will be one step closer to retiring the old allstarlink server.
Tonight’s change will not remove the old http://allstarlink.org/allmondb.php URL. However, it’s not going to be around much longer. If you have not already updated your astdb.php per the instructions in this topic, you should do so as soon as possible.
