New start up no wifi from new node
Okay I got a Raspberry Pi configuration with 9 selections which number do I select to update my country? One more question once "broken " does it stay broken until manually reset or rfkill unblocked?
Is that number 5 localisation options?
Localisation Options --> Change Wi-fi Country --> US United States --> OK --> Finish.
This is all over the Internet. The issue is the Pi builder has a bug. Might be cleaner to install 1.8.5 and reflash.
I have tried reflashing with 1.8.5 it didnt fix it. For the last 3 days....
Thanks for being paitemt with me and helping. I havent seen it at all until this evening.
So is the latest image update okay to use?
If you fix your country in raspi-config, unblock with the rfkill command I sent, and then reconfigure your wifi again it should work. There is nothing wrong with the ASL3 PI Image if that's what you're asking.
Yes it is. I need to re flash the sd card before attempting to set it up again? So off to give it all a try thanks again.
Good luck! Please report your results when you can. Thanks.
