Both above releases contain app_rpt.c version 0.235.
Significant changes included in app_rpt.c version 0.235:
Added 'exten' parameter to autopatchup function to allow dialtone-less access to contexts in extensions.conf.
Fixed 'telemetry' and 'morse' to allow for specification of
category name in rpt.conf file
Added dtmfkey/MDC-1200 keying support
and associated facilities
Added MDC1200 encoding and decoding.
Fixed duplex problem with vox operated control op phone access
Added support for 12.5/6.25 KHZ channels in the remote base
and changed default frequency to 145.000 so our friends in Europe won't accidentally
transmit outside their band
Added support for non-USA-standard repeater offsets
Fixed broken tm-d700 support
Add vox patch mode which works regardless of duplex setting.
Add support for Yaesu FT-100 remote base
<-- Hi Steve; I just built two new systems last week using the ACID ISO that was current last week! I do have another project on the back-burner... my own repeater site where nodes 2182 and 2424 are running. Node 2182 is running half duplex into an RC-210 repeater controller, which seems to be very volatile! The controller arbitrarily locks up, unlinks ports, resets the clock, and so on!
The two things that I really like about the controller are:
1. The ability to send out the ident without enabling the PL, so folks with a ctcss enabled receiver don't hear it!
2. The ability to turn off the PL before the carrier drops, again, folks with a ctcss enabled receiver do not hear a squelch crash - it's a seamless transition.
I believe the feature described in #1 has been added a little while ago. I am not sure about #2 - can the timing between the PL drop and carrier drop be varied to ensure that there is a nice seamless transition? - I recall trying this out some time ago but, as I recall, the timing could not be changed and we still heard a squelch crash.
