New Node Number Run Rate
We’re issuing about 175 nodes per month. That’s about the same rate as new users. So the run rate is looking really good. I do see requests for three or more nodes occasionally. In that case I usually grant one node and deny the others and send a gentle note explaining it saves node numbers and that you can have up to 10 sequential numbers by using NNX. If you reply that you need the nodes for whatever reason then I grant them, no problem. I’ve requested the other admins to do the same.
You can see the run rate here https://www.allstarlink.org/meta/new_req_month.php
NNX Documentation is here https://wiki.allstarlink.org/wiki/NNX
We are saving about 110 node numbers per month due to you folks using NNX numbers. That’s great so keep it up.
